Unable to resolve the problem by inserting operating system disc. Vista operating system.
SOURCE: pxe -e61: media test failure,
Welcome to fixya.
-The first thing to check is your boot order in the BIOS.
-Unplug from power, remove battery wait a solid 5 minutes and try again.
-Go into the BIOS and choose the Default settings (press F9 to set defaults then F10 to save and exit).
-It sounds like it can't find a hard drive to boot from so it's looking for the Network to boot from.
-If you have an external CD/DVD drive try to boot your OS from that (after changing the boot order).If it did not work then there is a big chance that the problem is a failed hard drive.
First disconnect any external devices connected to the computer except the mouse and keyboard.
This error usually happens if the hard drive is not getting detected by the operating system or due to bad hard drive.
First check if all the physical connections to the computer are set correctly.
If it is a laptop remove the laptop battery, wait for 5 minutes and then connect back the battery, check if it works.
If the above step does not work then you will need to run CHKDSK tool to check if there are any bad sectors on the hard drive would suggest running chkdsk which would scan for any bad sectors on the hard drive and if those errors are repairable if would repair and if it cannot at the end of the chkdsk scan you would see a message "found one or more unrecoverable error on the hard drive" which means the hard drive is damaged.
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
1. Insert the installation disc.
2. Restart your computer.
Click the Start button, click the arrow next to the Lock button , and then click Restart.
3. If prompted, press any key to start Windows from the installation disc.
Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click command prompt and in the command prompt typechkdsk /f and wait till the scan is completed and later restart the computer and check what happens.
http://windows.microsoft.com/en-US/windows-vista/Make-system-repairs-from-the-Windows-Recovery-Environment-from-Windows-Vista-Inside-Out
Important: While performing chkdsk on the hard drive if any bad sectors are found on the hard drive when chkdsk tries to repair that sector if any data available on that might be lost.
Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
To start the system recovery:
First please refer to the following thread to see whether it helps.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=796452&SiteID=17
I know that you are unable to start the current vista operation system and getting the error 0xc00000e9; the issue can be caused by the damaged system files or hardware device. You might first follow the steps below to exclude the possibility of system corruption.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
