Question about Car Audio & Video
Need two restors burnt out need color or size
I have a boss rev 755 that is burnt two little things out. need color or the size they are so i can replace them? On the board the numbers is r223 and r123? thanks
  • Anonymous Dec 05, 2008
    Here is what i have. BOSS REV 755 car amplifier. It has 2 burt out resisters. need color or the size of it .Here is some pics thanks
  • Perry Babin May 11, 2010
    If you don't get any other help, send me a few clear photos of the area so I can see what you have.
    babin_perry@yahoo.com
  • 117 Answers
Board numbers are usually the value , use multi meter on resistors to get proper value
Posted on Oct 29, 2009
1991 chevy cheyenne...I suddenly lost reverse and overdrive. I have to rev a little then back off to shift tranny. Please help me figure out whats wrong. Im a singe mom and funds are very tight. I need...
First, the basics...
How many miles are on the vehicle? Is it the original trans?
With engine running, in park, and idling, did you check your transmission dipstick to see if the fluid is low?
Is the fluid on the dipstick darker colored and have a burnt smell?
(Good fluid should be pink to red, not brown)
Oct 31, 2014 | Cars & Trucks
BOSS TU-3 Tuner will not work with power supply or battery
It was probably connected backwards in polarity from a power supply which burnt a diode. These things have backwards polarity of 9v adapters which means positive on the outside of the plug and ground in the middle, unless you have the original boss power supply.If you have a generic power supply, cut the plug off and switch the wires and try it.
Mar 01, 2013 | Boss TU3 Tuner
How do you factory resotore a Dell Opitiplex 755 computer?
If the hard drive was replaced or reformatted, the factory restore was erased. If so the only way is to load OS from CD .
Jan 30, 2013 | Dell Optiplex 755 Minitower Desktop...
Brand new alternator & good charge on battery when
a couple things,a wire going to the starter could be melted to the exhaust,a bad connection on the battery or starter solenoid ,started could be bad,brushes wore down too low and shorting out,or your battery may read good with a meter after charging but test your battery with a load tester,you may have a dead cell or cells or even a short inside the battery,when you turn the key the battery will short out inside and then all the lights are dim but if you just move the battery cables just a little,every thing looks normal until you try to start it again,this happen to me,every time my boss would try to start our service truck,everything would go dim,fan's would slow,my boss would yell to me,turn the cable to get a better connection,I did this a few times until I was bent down ,to look under the opened hood to see my boss setting in the drivers seat telling me to move the cables more,and every time,just click,then as I was bent over the battery to see my boss,the battery was only inch's from my head,it exploded,covering me in the battery acid,a piece of the top of the battery shot through my hair,leaving me with a gash across my head,with out hair,kinda like a over sized part,but bleeding,the acid never burnt me or hurt me at all,but the sound of the battery blowing up inch's from my head,I couldn't hear all day,just a load humming sound,,,so be care full when working with a battery that could have a short,and never buy new acid and add it to your battery,the two fluids ARE NOT COMPATIBLE,and the slightest spark from static will be enough to explode the battery.
Dec 30, 2012 | Cars & Trucks
What size blade fuse would I need for my D800.2 Boss amplifier? I took it to a shop to work on my music system ,and for some reason they threw away the fuse. I don't remember what size was in the single...
You need a 30 amp fuse according to Boss Audio's owners manual.
http://www.bossaudio.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=564&nav=0,2
Aug 02, 2010 | Boss AUDIO SYSTEMS D8002 Car Audio...
The OPTIPLEX 755 will not start
Open the case and look at the little black round things that look like soda cans. Those are called Capacitors. they are kinda like small batteries. They should have a shiny silver top. If they have anything oozing out or if they look like theyve popped like a popcorn kernel, then you have a faulty board. If your pc is under warranty, call dell asap. its an easy repair and its done the next day.
Jul 21, 2009 | Dell Optiplex 755 Desktop Desktop Computer...
Burnt out my Boss BR 1180 How do I repair?
this is a job for an advance electronic repair tech...try the manufacturer..next a tv repair shop..then an Audio Install shop...if that doesn't work out..i'll personally try to fix it..for lest than anyone else..its probably the tranformer output circuit overrun..that part of the board or component wil have to be replaced...good luck
Jun 16, 2009 | Boss Micro BR Digital Recorder
Boss br1180 burnt inside, who do I go to for repair?
The likely defective part is the voltage regulator. This should be fixble by any shop that handles audio gear. No special test equipment or parts are required. The regulator circuit should be fairly standard and simple. Where are you located so I can recommend a shop? Dan
Jun 16, 2009 | Boss Audio Players & Recorders
How do i get into world 4 and 7 on super mario bros ds lites
you haf to get to beat the bosses in world 2 & 5 with mini mario. or beat the boss in world 2 as mini mario, and do it 2 world 4 as well 2 save time.
Feb 18, 2009 | Nintendo New Super Mario Bros. for DS
Burnt down printed compartment part
Your mboard is killed.The chipset is the most difficult thing to handle with and if you have change in color in the board (normal color to a black color) its all over. You remove your HDD and get the inside data by fixin on to another machine.
Mar 09, 2008 | ASUS P5P800-VM Motherboard
Car Audio & Video Logo
113 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
