Upper radiator hose blew open - replaced the hose, but car won't start - it cranks, and battery is live, but won't turn over
SOURCE: need to replace the starter on a 1994 Geo Prizm
starters are actually pretty easy. usually just 2 or 3 bolts holding it on. Just disconnect the battery first. Remove the bolts and the starter and then installation is reversal of removal.
Hope this helps,
Lee
SOURCE: 1994 Geo Prizm LSI running one day won't crank next day
turns over and crank are the same thing,
so you are saying it does crank over but no start,right?
you need to determine if you have at least 50psi of fuel pressure in fuel rail at reed valve.
SOURCE: My 1990 geo prizm will turn over but won't start.
Being you replaced the fuel pump and that had no effect I would now check if you have spark if theres no spark check your distributor or coil packs if you have coil packs check the crankshaft position sensor that sensor if its bad could cause a no spark condition...
SOURCE: 1997 geo prizm wont start no power to fuel pump
look for blowen fuse or look for fuel shut off swich
It turns over (cranks), but won't start.
it turns out the head gasket is the culprit
