Question about Toshiba Satellite Satellite 5200 Series 15 SXGA LCD Display-LQ150F1LH16-P000353350 CD-ROM Drive
DVD drive some time works, some time does not
Hi there ... I am having a very strange behavior in DVD drive of my notebook. The DVD drive of my Toshiba notebook some time reads CDs (once in a 100 tries), and most often it just refuses to respond. Some times the drive reads the CD after I clean the drive, some times when I insert the try by applying pressure on a corner of the tray. But out of say 100 tries, the drive responds once or twice. I could not figure out any standard procedure to make it work continiously. Is it time to give up hope on the drive?? or is it some mechanical trouble which can be fixed by some rudimentary correction? Regards, Devashish
  • 22 Answers
First try uninstalling the dvd drive go to start/control panel/system/hardware/device manager look for dvd/cd-rom drives right click dvd - uninstall reboot afterwards so winxp will re-install drivers if this does not work, go to toshiba.com look for downloads for your dvd/cd drives just make sure you have the right model so the file you download will be exact and correct
Posted on Feb 01, 2007
Brand new apple dvd drive will not accept dvd
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 24, 2014 | Apple MacBook PC Notebook
My HP dv9610us doesn't see my DVD player. Not seen in "My Computer" and not n the "Device Manager"
HI there,
Here's a link to Microsoft's automated tool for restoring unrecognized DVD drives. It doesn't work every time, but alot of the time it does.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Best WIshes,
Marcus
Sep 15, 2010 | HP DVD DRIVE DVD Drive
DVD drive not working
Hi.
Your dvd drive is gone mate.
Replace it.
Mar 09, 2010 | ASUS G2Sg-A1 PC Notebook
My HTC touch is dead after WM6.1 upgrade from XDA developers
Hi. Have you tried reflashing your device (Assuming you have done before with the instructions from the xda-developers) with another ROM from xda-developers? If it doesn't work, you can try to reflash your device with an official ROM from the HTC website. Hope this helps.
Jun 26, 2009 | HTC S620 Smartphone
Dvd drive bay does not lock
When this happens the drive lock is faulty, or there is a control problem.
Unplug laptop power cord and remove battery for ten minutes.
If the DVD still does not lock when there is no power, and when you connect everything back, then DVD latch has a fault, probably a mechanical problem.
If laptop is new get it replaced, or get the DVD unit replaced. Contact the retailer for service and replacement conditions.
Regards
Sep 06, 2008 | Compaq Presario Notebook
2 SATA Drives will not burn DVD-R but will burn DVD+R
Well, for one thing, your system is faster then mine. AMD Athlon X2 4000+ 2.10 GHz, 2GB, BIOSTAR A770 A2+ 160GB SATA. Anyway, what sata port did you install these DVD-Burners to. I know it shouldn't matter, but humor me for a minute. I have mine on the last two normally. Seems to work fine. Try it and see.
Let me know
comier957
Aug 07, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Dvd drive not working
hi, sometimes manually cleaning the lens lcarefully with an earbud wiil help.. let me know..
Nov 24, 2007 | Toshiba Qosmio G25-AV513 Notebook
DVD/CD-RW drive
you might have to update your dvd driver. Go to my computer and then properties,then disk manager. Look for the DVD driver and then update it...You might also update your windows..Hope this helps...
Oct 19, 2007 | Toshiba Satellite A15-S157 Notebook
Issues with DVD Rom Drive
Mine did that too but for whatever reason when I did a system restore back to a time when it didn't do that... it worked.
Sep 06, 2007 | Gateway MX6445 Notebook
Toshiba Satellite Satellite 5200 Series 15 SXGA LCD Display-LQ150F1LH16-P000353350 CD-ROM Drive Logo
238 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
