250Gb ATA HDD will not clone - Computers & Internet
  • 1 more comment
  • Desktopsbyduck-Computers
    NEED TO KNOW IF YOU ARE CLONING TO ANOTHER DRIVE IF SO IT MUST HAVE A LEAST 250Gb. OF AVAILABLE SPACE
  • Daniel Martinez
    Daniel Martinez May 11, 2010
    to add to MULLYHARLEY/S "" clarification Request ""::
    I see that PETER17:: said that its was an ATA 250 GB,
    What o/s [operating system] win_vista,xp,me,98?? are you using.?and what type of software are you using to CLONE ?
  • Frank Doll
    Frank Doll May 11, 2010
    Is the new drive an ATA or SATA or serial or parallel?
    The new drive must match the specs of the old drive except for volume (and sometimes even that). Is the new drive properly formated to the old drive? NTFS will not clone to a FAT32 drive etc...Check software requirements and all connections?
    Genius:
  • 1,061 Answers
I TAKE IT YOUR CLONING TO ANOTHER HARD DRIVE IF SO IT MUST HAVE THE MINIMUM 250 Gb CAPACITY
Posted on Nov 30, 2008
Which USB cradle works for a WDAC24300?
Okeba 2.5" 3.5" SATA IDE Hard Disk Drive HDD Dock Station Clone With USB HUB card reader - CA130 From - Rakuten.com,
or: Sisun 2.5"/3.5" IDE SATA HDD Docking Station +Card Reader Hub - From Amazon.com
Feb 12, 2015 | Western Digital AC24300-00LK 4.3gb 5400rpm...
WHAT HD & SIZE RECOMMENDED FOR MY GATEWAY 500S PC WITH OS XP?
You cannot use a SATA (serial ATA HDD in this machine. You need a PATA (parallel ATA) HDD, also known as IDE, ULTRA IDE, ULTRA ATA. This has a 40-pin ribbon connector & a 4-pin power connector.
Sizes generally available would be 80GB up to 250GB, although very few PATA drives are now sold since SATA is the new standard.
Jan 25, 2013 | Gateway GT5220 PC Desktop
We cloned an older 58GB drive to a WD2500BEVT 250GB drive (using Acronis True Image 2011). The WD 250GB drive is now reporting as 58GB to BIOS. I've 0-filled it with different utilities. no...
Good day!!..As far us i know that cloning or ghosting should be the same specs of hard disk..Since you want to cloned the 58gb,so you should be use 58gb also and not 250 gb,thats why bios detecting some different utilities..ok thanks..
Aug 19, 2011 | Western Digital WD Scorpio Blue WD2500BEVT...
I want to upgrade the HDD of a Toshiba Satellite P200-156 to 500GB/640GB/750GB or more if possible but I'm not sure which specifications must be compatible. The 250GB HDD is a Fujitsu MHX2250BT Serial...
I think its okay to upgrade your HDD till 1TB, just make sure that HDD have serial ATA port to connect. my little advice is when you want to upgrade your HDD is look your mainboard specification, because HDD is work when it can recognized by mainboard. hope this useful, regard riyan.
Jun 08, 2011 | Toshiba Computers & Internet
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C...
Install a partition manager program like
http://www.partition-tool.com/personal.htm
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
Mar 23, 2011 | Western Digital Scorpio Blue 250GB PATA...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
I recently inserted a second Harddisk into my desktop which has a capacity of 80 Gb but when go and check my disk size in windows it shows as 9.9 Gb.. anobody know how to fix this. I'm running on...
Hi Good day!! Maybe the HDD that you've been inserted was a cloned HDD, my solution to this was to format the HDD that you've been inserted..
Oct 08, 2010 | Computers & Internet
What is the max hdd capacity I can install in a HP ZD8000 laptop?
Your computer uses ATA drives which topped out around 250MB simply because manufactures switched over to SATA drives. It is a pain to change out disks on laptops since you can only have one internal drive. You then have to reload everything.
Here is one I found: Western Digital Scorpio Blue WD2500BEVE 250GB 5400 RPM 2.5" ATA-6 Internal Notebook Hard Drive -Bare Drive
  • 250GB
  • 5400 RPM 8MB Cache
  • ATA-6
I'd consider one of the external USB disks instead to store your data, pictures, etc. You could then put it on your desktop or on a new notebook.
Sep 16, 2010 | HP Pavilion zd8000 Notebook
How can I replace my 30GB ultra ATA EIDE HDD with
Purchase a solid state drive, 2.5" for laptops 3.5" for desktops (or use an adapter for notebook drives with a 2.5")
Connect your IDE cable (and power cable on desktops) to the drive, install Windows and you are done!
If you want to keep your existing data, get an external enclosure for the appropriate sized disk and use a program like Norton Ghost or Acronis True Image to clone the existing drive to the new one, then swap the two drives (SSD from enclosure to internal, other drive out to enclosure)
Comment if you need more information!
Feb 06, 2010 | HP 100GB Ultra ATA/100 EIDE hard drive -...
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Computers & Internet Logo
24 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
