Home | Panasonic | TH-42PWD6UY 42 in. HDTV-Ready Plasma Tel... | Plasma TV-power lig...
Panasonic TH-42PWD6UY 42 in. HDTV-Ready Plasma Television
Problem for Panasonic TH-42PWD6UY 42 in. HDTV-Ready Plasma Television
Plasma TV-power light does not come on
By Dwan on Jan 21, 2007
My 42" Plasma TV has always been plugged on the outlet. Today, I found there was no red light on the TV. I tried to unplug and re-plug, there was no power come to the TV set. I don't see there is any place for fuse replacement or other opening that I can check. Any suggestions?
Same Problem
May 17, 2009
-   i have a 32" polaroid lcd. today i unplugged it to switch cable boxes. when i plugged it back in nothing.. the little red light that means its even getting power isnt even on-   ifoundu08
Apr 20, 2009
-   I have a 32" Panasonic TV, I turned it on oneday and it blew the fuse in the back of the TV. I replaced the fuse andsee nothing else wrong. I switched outlets and it still blows. -   JoeEpson
Apr 16, 2009
-   One year and 2 months.. i.e just enough to get past the free 1 year warrantly periosd...and I have the same problem. Now, a service guy in going to make a PAID house call.
Why the hell I bought a national tv? Crazy I guess. -   Guest
Apr 05, 2009
-   my 50 in samsung startes to make the mealody sound when i plug it in. it turns on and off . i am out of my money. really could use the help.-   hsandhu58
Mar 08, 2009
-   i got a big screen tv i wanna by from my cousin for 20 bucks and gonna take it to the shop but the thing is that card has a shortage in and it want come on i just bought a toshiba from him that he thought didnt work 52 inch for 60 bucks and brought it home my husband went to hitting button taking it off regular tv which it was set on that and brought it to a house that had cable and the tv came on.. show perfect no problems yet my cousin thought it didnt work just wondering if i should take a chance with this other tv it doesnt come on after u plug it in no should no nothing and the card u plug into the wall it all batter taped up and all so someone help and give me some advice on what to do.. -   missjesk
Best Solution
posted on Jan 03, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
A blown internal fuse would cause things to appear completely dead. It is not intended to be user serviced. If you do find a blown fuse, never replace it with a larger size. Using an oversized fuse may cause additional damage. If the same size blows again there is some sort of fault, typically something like a shorted diode, electrolytic capacitor, or switching transistor.
There could be more than one fuse. Sometimes there is one on the AC power coming in, and one or more on various outputs from the main power supply. The AC line fuse may fail simply from a nasty surge coming down the power line. Other fuses usually blow from internal faults.
The main page for this site suggests there are service manuals here. I haven't seen any. They'd be very helpful to someone like me that understands electronics. They're generally beyond what end-users can understand.
Solution #2
posted on Jan 17, 2008
Very Helpful)
rox z
Rank: Apprentice
Rating: 99%, 10 votes
i have the exact same problem. when i took it to the repair shop it came on and he stated that it was on the wrong input. so i took it home plugged it in and watched it ffor a couple hours that night. the next morning it turned on for about half a minute then it shut off and never turned back on again. what should I do?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on May 14, 2008
Very Helpful)
Goater5000
Rank: Master
Rating: 94%, 10 votes
there is a few things that can be done. I have this same issue, and i braved the 40 screws and took it appart.I have another posting that shows photo's check it out so far http://www.fixya.com/support/t566714-akai_plasma_tv_5_blinking_red_lights
Was this helpful?
Yes
No
Solution #4
posted on Sep 09, 2007
Very Helpful)
LCDMAN2000
Rank: Apprentice
Rating: 92%, 5 votes
Sounds like a power supply issue.
Was this helpful?
Yes
No
Solution #5
posted on Aug 23, 2007
Helpful)
nineteen
Rank: Apprentice
Rating: 91%, 66 votes
The fuse is located on the inside of the tv. you have to remove the the rear panel as if repairing.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #6
posted on Dec 03, 2007
Helpful)
mhlady
Rank: Apprentice
Rating: 90%, 5 votes
JoeJoe206, your problem sounds the same as what just happened to my FWD-42PV1, which was 2 months past its warranty. When i plug it in, the green light goes on and i get clicking every few seconds for about 15 seconds, then it gives up and just goes to red. The picture never comes on. There was a pretty detailed diag manual i found online that indicated that it is most likely the A board or the G board (the power board) but the troubleshooting section looked translated from Japanese. Both A and G boards are pricey boards ($400/$550). If you find anything interesting, drop me a line at markahlady -at- yahoo.
Was this helpful?
Yes
No
Solution #7
Helpful)
angelo1406
Rank: Apprentice
Rating: 85%, 1 votes
check if one of the fan inside the tv is off if one is off you have to changed both
Was this helpful?
Yes
No
Solution #8
Helpful)
Goater5000
Rank: Master
Was this helpful?
Yes
No
Solution #9
posted on Feb 21, 2008
Somewhat Helpful)
mumblyjoe
Rank: Apprentice
Rating: 77%, 3 votes
If you are under warranty and have a TV over 32", then they should come to you and repair it. Call the help line and they'll set it up. It could take a week for a local tech to make it.
Was this helpful?
Yes
No
Solution #10
posted on Jan 21, 2007
Somewhat Helpful)
Clearwater
Rank: Apprentice
Rating: 76%, 7 votes
Try plug it somewhere else in the room or plug something that you know works in the outlet where the tv was plugged to make sure there is current
Was this helpful?
Yes
No
Solution #11
posted on Mar 23, 2008
Somewhat Helpful)
folklove
Rank: Apprentice
Rating: 85%, 8 votes
i can fix it easy as hell if u want 2 know how then call me 1847-507-2504
Was this helpful?
Yes
No
Solution #12
posted on Apr 04, 2009
Very Helpful)
stacyb123
Rank: Master
Rating: 96%, 15 votes
You have burned an internal fuse on the main power board. There are 2 right next to where the main power line plugs in ( after the noise filter ). Yes, you will have to unscrew the rear plate to get to it ( about 24 screws ). You just follow where the lead goes from the plug - you will see where the fuses are - right next to where the plug mounts to the power board. To check this set your meter to ohms and check for continuity - odds are one of the two fuses is done. THIS IS A PANASONIC SPECIFIC FUSE - it cannot be replaced with one that looks like it or fits the same slot. This fuse is a time-delay slow burn fuse and replacing it with anything other than the correct type will cause more damage and possibly total the unit. The panasonic part number is K5D802BNA005 and is available from several parts retailers - just google "panasonic part K5D802BNA005" and many reputable firms will come back on the search. They cost approx. $1.95 US ( so the shipping is probably 7.00 more ) Hope this helps and be careful of the internals and static electricity from your body.
Was this helpful?
Yes
No
Solution #13
Very Helpful)
andy lufc
Rank: Guide
Rating: 79%, 8 votes
if its not the internal fuse need new power supply bourd send me modal number and i will see if ive got one in my spare parts
Was this helpful?
Yes
No
Solution #14
posted on Oct 31, 2008
Helpful)
djchillsnyc
Rank: Guru
Rating: 89%, 73 votes
if you have blinking lights or no lights or steady red light this is a power problem the best solution is to get a service manual for your set and find the symtoms and there is usually a trobleshooting guide for the repair in the service manual a steady red light means the p a board needs to be checked or replaced blinking lights can mean a fuse is blown or a board may be bad no lights may mean bad connection bad power unit or fuse before you start guesing or calling expensive repair company do your research find a service manual and if you really can handle this fix then you can get a used non working tv and switch out the parts with out spending a fortune..most people break the screens so theres plenty of lcd's being sold as is for parts try ebay or craigslist ..
hope this helps
Was this helpful?
Yes
No
Solution #15
posted on Dec 18, 2008
Helpful)
daveebidding
Rank: Apprentice
Rating: 88%, 6 votes
the solution is, DONT BUY PANASONIC PRODUCTS!
Was this helpful?
Yes
No
Solution #16
posted on Jan 05, 2009
Not Rated)
todd34
Rank: Apprentice
Rating: 0%, 0 votes
Memorex MLTD2622 26 in. LCD TV TV/DVD Combo The Tv is on but picture. Wheni first turn on the tv, the memorex pops up then a black screen. what do you do I have checked all of the pluggs and connections and still no help.
Comments:
Jan 05, 2009
- Memorex MLTD2622 26 in. LCD TV TV/DVD Combo The Tv is on but picture. Wheni first turn on the tv, the memorex pops up then a black screen. what do you do I have checked all of the pluggs and connections and still no help.
Was this helpful?
Yes
No
Solution #17
posted on Feb 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution:
DO NOT BUY GATEWAY LCD TELEVISIONS.
China does not supply any service manuals to the usa. The technical department at GATEWAY do not have any manual are
very poor technition help.
Solution #18
posted on Dec 28, 2007
Not Rated)
jstig
Rank: Apprentice
Rating: 0%, 0 votes
I had the exact same problem and had to return the unit for repair. After examination I was told it was a power supply and they would fit a reconditioned (as they don't make new ones! ) for $750 AU.
Several visits to my home, the repairer, angry phone calls and about 10 weeks without a working TV and I got the unit back. The power works fine but after several weeks I am seeing white snow appearing on the screen !
Was this helpful?
Yes
No
Popular Solutions for Panasonic TH-42PWD6UY 42 in.
Questions and Unsolved Problems for Panasonic TH-42PWD6UY 42 in.
Do you recommend Panasonic TH-42PWD6UY 42 in. HDTV-Ready Plasma Television?
Answer
Answer
What lead do I need and can I get sound from my amp as well?
Answer
hello my 42" bush plasma seems to have no power going to it so i looked on the internet and it... (More)
Answer
i have a technika tv when switch it on blue light appears.then i try use the remote the blue light... (More)
Answer
My plasma turns on and has a picture but then turns green. What could it be?
Answer
toshiba tv 42 in model tz50v61 model tz50v61 wont turn what could be the cause
55 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 23, 2009
My Panasonic TH 50PX600U plasma power light just went out. the power would sometimes come back on .it would play for 2-5 mins and then power light goes out again sometimes for a whole day. I'm located in Trinidad West Indies and have no Panasonic Service Centers around so I went to my electronic technician ( fairly allright one too)and Kabam. After replacing 1 burnt capacitor and re soldering some cold solder on two boards...the TV is working new. I just thought I'd share this on the net to help others
vernondsingh@yahoo.com
Comment by jiwi1216, posted on Sep 04, 2008
I have a 50' LG plasma and i have had it for about 7 months at the most and it decided to stop workin in the middle of watchin it..i have no power light(red or green) no sounds nothing its just dead..i would really like to to know what this problem is and why its doing this.
Comment by Guest, posted on Sep 04, 2008
black screen" green light is on!! but picture will not come on, what could be the problem?
Comment by Guest, posted on Aug 28, 2008
power out of plasma tv
Comment by emmanuel01, posted on Aug 22, 2008
My Hitachi 42PD7200 power led does not come on. No power at all. Tried other devices work find on the outlet. Tried a different power cable, change the fuse inside the tv but no luck
Help appreciated
Comment by catesj05, posted on Aug 02, 2008
Same problem - no red or green light, no power. TV is absolutely dead and not even a year old! I tried calling Spectroniq help line and they have filed for bankruptcy. Any suggestions
Comment by tjonz, posted on Jul 24, 2008
I am having the same problem. I am getting zero power on the T.V everything else plugged in to my surge protector has power. I have tried different outlet and that has not worked.
Comment by annettemire, posted on Jul 22, 2008
I puchased the 42" plasma with ambianlight 18 months ago and the power went out. I called Philips but they have no solutions, except to send it to one of their approved service centers. What a nightmare!! It has been there for 2 weeks and no solution. I've been told by their service tech. that the entire "power pack" may need to be replaced and could cost $500 plus labor.
Comment by grubb9, posted on Jul 18, 2008
TV LIGHT DOES NOT COME ON SOO TV WILL NOT TURN ON .I CHECKED ALL OUTLETE AND PLUGS
Comment by faster78, posted on Jul 13, 2008
No power or lights. Fuse is not the problem have checked and it is good have voltage pass the fuse but then what??????
Comment by 03jacksmith, posted on Jun 22, 2008
my tv screen will not turn on i have change the fuse a number of times it turns on for a second then blows the fuse and turns of but i have power to my reciver
Comment by Guest, posted on Jun 20, 2008
no power to tv red light is not on. I have power to the receiver
Comment by Guest, posted on Jun 15, 2008
power went and foung
Comment by apulia, posted on Jun 14, 2008
my tv power light does not come on i have no sound no picture
o meu plasma Hitachi 42PD3000 TV Plasma 42 polegadas
acende a luz verde,passado alguns segundos muda para laranja,e o ecrä fica sempre escuro,como se estive-se desligado,o que podera ser?
Comment by Guest, posted on Jun 14, 2008
50PB4D 50 in' .I have power to the TV as the red light is on but the green light doesn't activate so I have no picture or sound. I have tried switching off at the mains for 24 hrs and all the buttons on the TV and remote with no luck..Any Ideas?
Comment by Guest, posted on Jun 03, 2008
same here
Comment by ceetv, posted on May 18, 2008
T.V. power light does not come on i have no sound no picture
Comment by BAMOUT, posted on May 16, 2008
I'm back. BAMOUT is my name. Does the DYLT32B have a fuse on the power supply? Thanks BAMOUT
Comment by joeldavid07, posted on May 10, 2008
My TV will not turn on there is a red light that keeps blinking on the front of the TV where the green light normally is when on
Comment by hard_line222, posted on May 10, 2008
changed the picture from stadium to zoom mode. played for a few minutes then screen went black, power lite blinked red and yellow, unpluged it pluged it back in and stand by lite comes on like its suppossed to, turn power on and power lite comes on green like its supposed to but still no pitcure. any ideas?
Comment by Singulto, posted on May 03, 2008
My 4242 works for about half an hour then it switch off and the power led starts to blink red: the manual say something about power stability... Any solution? Any news? Best regards.
Comment by dinarae, posted on Apr 30, 2008
Comment by george38, posted on Apr 30, 2008
I can shut my tv off, but if I can back after like 8 Hours, it will no turn on, is an lcd hd polaroid tv. please help
Comment by Guest, posted on Apr 24, 2008
I have a 42" Panasonic plasma TV. I tried to turn it on first using a remote control then manually. Nothing happens.
Comment by angelo1406, posted on Apr 24, 2008
i have the same problem
Comment by Guest, posted on Apr 22, 2008
Plugged in and red light is on but appears to be flickering. Unable to turn on with remote control or on-off button on TV. No audio as well.
Comment by Guest, posted on Mar 18, 2008
no power when pug in tv
no power at after i unplug the set
Comment by MickeyBee, posted on Mar 18, 2008
When using either remote or panel button to power TV on, the red light goes green, you hear relays clicking and then within seconds, the light goes red and TV is in standby mode.  Called NEC who gave info for local guys they recommend for repair; even after describing problem over phone, they said they could come to look at it for $175.  They were here less than 10 minutes, tried to turn the TV on and confirmed what they had been told over the phone, and then diagnosed that it needs a new scan board and command board at a cost of $1300 plus!  Don't waste your money like I did - just buy a new one.  And I can guarantee I won't be buying another NEC ...
Comment by Guest, posted on Mar 11, 2008
red or green light does not come on.
Have to control everything from the console since remote won't work without the red or green light being on.
Batteries in remote are fine.
Comment by JimPearsall, posted on Mar 01, 2008
Absolutly no power to the TV. I have unplugged, checked circuit breaker, replugged and no power.
Comment by Guest, posted on Feb 21, 2008
Comment by BIG IRISH, posted on Feb 20, 2008
AFTER REBOOT GREEN POWER LIGHT COMES ON, WHEN FRONT PANEL POWER BUTTON IS PUSHED ,LIGHT TURNS RED. NO PICTURE OR SOUND, NO OSD. MAIN POWER AND DIGITAL BOARDS HAVE BEEN REPLACED. EE-PROM SEEMS TO OPERATE, COULD NOT FIND ANY SHORTS ON SCAN BOARDS OR BY CABLE DISCONNECT?
Comment by Guest, posted on Feb 14, 2008
When i put the tv on only the green light is come up and no power
Comment by rox z, posted on Jan 17, 2008
My 27" Plasma TV has always been plugged on the outlet. Today, I found there was no red light on the TV. I tried to unplug and re-plug, there was no power come to the TV set. I don't see there is any place for fuse replacement or other opening that I can check. Any suggestions? The TV shop said it was on the wrong input,but that is not the case becuase it will not even turn on.
Comment by nixfix, posted on Jan 10, 2008
power supply bad need to find new one
Please email me.
Comment by zolzant, posted on Jan 08, 2008
I was watching television and without any warning, my 2 1/2 yr old Akai plasma tv turned it self off and I can not get the tv to go back on.
Comment by larrysch, posted on Jan 04, 2008
Have a Philips 23PF5320 LCD TV - it just died . the power light is off and there is no picture or sound
Comment by eman123, posted on Jan 03, 2008
my tatung 42 inches red light comes on but nothing shows
Comment by Guest, posted on Jan 01, 2008
42 inch Akai just stop working and power will not turn on.
Comment by jaym, posted on Dec 27, 2007
I have a 42pd3000 & connection box for connecting other things like a dvd playstation etc ..it keeps switching off and goes on stand by clicking on and then off and now shows out of sync on screen.
Comment by debee1, posted on Dec 25, 2007
MY DELL TV HAS A BLUE LIGHT AND NOW THE TV WONT POWER ON AND THE BLUE LIGHT ISNT EVEN ON MY SON PLUGGED HIS XBOX TO MY TV AND NOW NOTHING IS WORKING INCLUDING THE XBOX
Comment by smrm, posted on Dec 10, 2007
I have the same problem but after the fuse was replaced it blew as soon as it was plugged in. My Tv is an LG, 32LX1D.
Comment by Pepitone, posted on Dec 09, 2007
That is what I'm experienceing - no power to the TV. Yes, it's plugged in - but like the others no red light. It's just not coming on.
Comment by joejoe206, posted on Nov 30, 2007
My 42" Sony Plasma TV (PFM-42B2) was working properly and suddenly it stopped working. The red light comes on (changed itself to standby mode: like I turned it OFF). I tried to turn the unit ON and i can hear some clik like it's going to start,but it switched itself from Green ON to red light OFF. What could be the problem? Please help..
Thanks.
Comment by uhoh, posted on Nov 20, 2007
hi.
i have basically the same problem, except my sony hdtv is the european model 32U2000. I also get a clicking noise...but no power light and obviously no power. could it be the fuse? if so, when i open the back will the fuse box be obviously there, or will i need to uncover something else first?
thanks.
s
Comment by Guest, posted on Nov 20, 2007
have the same problem, only my tv is the european model 32U2000...
if i open the back, will i see an obvious fuse box, or ?????
Comment by Guest, posted on Nov 06, 2007
the red light comes on, but does not turn to green
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic TH-42PWD6UY 42 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
