Question about Olympus Cameras
I am trying to take photos with my Olympus FE-140, which is supposed to be a cinch to use and has been until now... Maybe I pressed something I shouldn't have, but it keeps taking me to Card Setup, and my options there are either Power Off or Format...help?
  • 593 Answers
Format the card in a Fuji. Oly cams dont do a very good job formattng xD cards. Take it to a cmaera store and see if there is a Fuji you can use to format the card.
Posted on Nov 30, 2008
Olympus 5020 lens stuck, turns off after power
Please check if the digital camera batteries in it are effective,if the battery have compatibility problem ,no strong enough power or voltage,the refered satuation maybe happen.Change the olympus battery for a new one ,then try again. After use some years ,the olympus battery life usually end.
Jun 02, 2010 | Olympus FE-140 Digital Camera
Need a new instruction manual for our Olympus Digital FE 140 camera
Hello. Click the link below to download the 108 page manual for your camera. Save a copy to your computer for future use.
builderdale
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/bman_fe130_e.pdf
Mar 03, 2010 | Olympus FE-140 Digital Camera
My camera is olympus fe-140 so it connect tecnical proplem which says write protect so what can i do
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, write-protecting it. The position nearest the contacts unlocks it.
If that doesn't solve the problem, try a different card.
Feb 02, 2010 | Olympus FE-140 Digital Camera
How do I delete all the photos off of my olympus FE-310 (formating the card in set up didn't work)
Formatting in the camera should have worked. Make sure the slide switch on the side of the card is in the unlocked position. With most cameras, when you bring up a picture and press the delete button, it gives you the option to delete that one picture or all of them. Have you tried that?
Dec 04, 2009 | Olympus FE-310 Digital Camera
I have an Olympus fe-140 and it has worked great untill recently. i go to download oictures to my laptop and evrytime i get the dreaded blue screen of death and the laptop reboots until i disconnect the...
You'd have to go into your Device manager and check to see if you can update or reconfigure the driver for the USB port you are using.Also if you've got another USB try switching to it. I'm sure you already have but, ya neva know!!!
Sep 09, 2009 | Olympus FE-140 Digital Camera
Need to download olympus fe-140dig.compact camera Service Manual
Well you can download the manual in pdf format from here: http://www.retrevo.com/support/Olympus-FE-140-Digital-Cameras-manual/id/200bh637/t/2/..................................sodeep
Aug 19, 2009 | Cameras
Olympus FE-140 ok except that flash does not work
Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
Dec 28, 2008 | Olympus FE-140 Digital Camera
Olympus FE-140
Yes I had the same problem, however, where is says "push to eject," it means to push the the memory card down and it will eject. You pushed down the latch for the plastic door cover. Try pushing something into the hole so the camera thinks the door is closed. I am still having trouble with mine. Hope this helps alittle.
Sep 16, 2007 | Olympus FE-140 Digital Camera
Software
You might try using different (and better) software instead. Preclick offers a free organizer (www.preclick.com) that will download photos from most cameras. It's really fast and simple.
Mar 10, 2007 | Olympus FE-140 Digital Camera
Cameras Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
