I had one that I bought brand new several years ago and I loved it..I got it out this spring and it won't focus, all the pics are blurry..so having all the accessories and drivers etc..I went on eBay and got another one. It doesn't focus either. They both flash red all the time.
SOURCE: I can not get my Kodak Easy share c633 and c300 to turn on
have you checked the battery terminals if they have rusts where the battery sits?
SOURCE: Kodak Easy Share M873 suddenly not working
What happened is that the camera got turned on in your pocket or somewhere and the lens got jammed trying to open up. The problem is that the outer lens ring is not turning all the way and the camera doesn't fully load.
Solution 1: Put the camera into the charger, press the power button so the green light is flashing, unplug it from the charger. The camera will try to realign its lens. (You might have to do this a few times.)
Solution 2: Manually help turn the outer lens ring clockwise when it turns on.
SOURCE: I have Kodak Easy Share CX7430. I have put in new
Enilra, sounds to me like you might have the button that takes the photo stuck in the down position. Without turning on the power, put you finger on the button and press down on it while you move wiggle your finger around. Get a good look at the button and see if You Can See If The Button is returning to the UP Position. Withour seeing your camera in person this would be my guess.
SOURCE: My kodak easy share z712 IS won't power on, I have
If the camera will not power on at all, then I have no where to start. Nothing can be done except repair. this camera will need repair, or sell it as parts or as is on a site such as Ebay.
Call Kodak, and tell them the problem,it just might be that they may take the camera back. It may be worth the time. Go to the website for kodak, find the support and then find the service or repair department. Call them.
SOURCE: My kodak easy share z1275 wont power on. I have
read this post, worked for me!
http://www.fixya.com/support/t3489422-camera_will_turn_second_go
