Question about Maytag PYE2300AY Electric Dryer
Maytag Dryer working but not heating up.
I took the heating element out and had the the thermo checked and everything is ok.Put it back together and it heats up but not real hot.It keeps short cycling. What do you think the problem is?
  • 116 Answers
Possible air flow problem,, check exhaust hose and sure not clogged up needs air flow, if long dry times repl/ coils/ only on gas models /if electric./ repl/ hi limit thermostat,// and safety thermostat ,,u need 240 volts 120 to turn on dryer and another 120 to heat ......
Posted on Nov 30, 2008
My maytag dryer gets way to hot. you cant even get your near heating element. you can even see it glowing. what could cause that.
Were you running the dryer without the lint screen in place? sound like you got something on heating element. Also the heating element does glow orange when it's on. If it keeps on getting too hot, there is a sensor that shuts off element after a certain temp. This may not be working right. Just what I came across working on my own in the past.
Sep 11, 2012 | Dryers
My Maytag MDE4000AYW electric dryer is not heating and drying my clothers
Check for a blocked vent. If the vent is blocked or restricted it will cause the thermo fuse to blow. If the thermo fuse is not blown check for a broken heating element. I hope this may help.
Jan 02, 2012 | Maytag Neptune MDE4000 Electric Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Maytag Model PYE2300AYW Heats for short time
In most every case i have seen this happen, the dryer is connected to flexible venting. Flexible venting is the worst thing for a dryer. Rigid aluminum only. If your element shuts down that fast, it is definitely an air flow problem. Remove the front, clean out the lint screen housing from the spout to the blower, all the way to the lint screen so that it looks factory clean. The venting must be absolutely clean as it was the day it was put in new. The outside application, whether it is louvers, vent flapper, or ball vent, must be clean and operable as a new one. Once again, my suspicion is the venting as it is most likely a flexible type of venting with either excessive length or restricted flow. A dryer can only be vented for 30 ft. counting 5ft for every elbow and 5ft for the outside application. But the flexible equates as this...for every 1 foot of flex you must add 5 foot because of air restriction. I am surprised that the non resetable fuse has not blown yet. ( it will, trust me.)
Mar 31, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Jan 04, 2009 | Maytag HYE3658AY Electric Dryer
Kenmore 110.66712690 66712 ser.#mf3411314 not heating
ck the thermo fuse on the lint duck inside dryer its the white one also ck the thermo fuse on the element housing the one near the back dryer
Mar 06, 2008 | Dryers
Dryer doesn't dry
TAKE THE BACK OFF OF THE DRYER AND CHECK AND MAKE SURE THAT YOU HAVE POWER COMING TO THE ELEMENT WITH DRYER RUNNING IF SO THEN CHECK THE ELEMENT WITH A OHM METER AND SEE IF IT IS BROKEN, IF NOT MAKE SURE THAT THE THERMO DISK IS CLOSED WITH THE OHM METER, IF IT IS THERE IS PROBABLY A THERMO FUSE UP ON THE ELEMENT CAN THAT IS BLOWED.
Feb 14, 2008 | Whirlpool LTE6234D Top Load Stacked...
MAYTAG PERFORMA ELECTRIC DRYER WONT START
Same thing as other owners above...Dryer is five years old and is in need of a good cleaning of lint build-up. Model no. PYET444AZW.
I put a large load of clothes, which probably should have been spun again, into the dryer. When I returned the clothes were still basically wet, and the light in the dryer would not come on, and nor would the dryer start.
Tested the circuit breaker. OK. Tested the outlet with a tester pen. OK.
So in searching the internet for a solution, I found and read this string. Found the fuse, called my local appliance parts store and bought a thermal fuse kit for CDN$48 (incl sales tax). Kit came with three fuses.
Just opening the top of the dryer was a chore for a complete novice. However, the entire top is hinged at the back -- so at the front of the machine, just gently poked a slot screwdriver in the gap ringing the sides near the top, twist screwdriver and lift. Big fuse is easily accessible at the top near the back of the drum. It's a round thing about the size of a quarter screwed into a metal frame with two crimped-on wires coming out the top. One screw to removed the frame. Then detached the crimped-on wires, and removed the fuse from the frame with two more screws. You will need a smaller size ratchet or nut-driver.
While you have it apart you might as well change the second nickel-size fuse, too, although it is more of a pain.
You have to remove the coiled elements, which are basically just big springs. They come out with one screw on the right and a little finesse. The second fuse sits on the right-hand side of the metal box surrounding the coiled element. The screw for the coil also held the frame for the fuse in place, but the frame will still be secured to the box with a couple of small tongues. So you will still need to kind of lift and pull up on the frame housing the fuse. It requires some patience and finesse. Remove the crimped-on wires, and change the fuse.
Of the two smaller replacement fuses that came with the kit, there was one marked for a gas dryer and another for electric. (The big fuse was good for both.)
Then start putting it all back together. Took me two hours in all. But now that I have done it once, it would hopefully take me only 30 mins. now.
Finally, my replacement instructions suggested cleaning out your machine and removing the lint and other burdens which probably overloaded the fuse in the first place. So I bought one of those specialized lint brushes to clean out the trap and the exhaust hose and vent.
Sep 25, 2007 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
121 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
