Question about HP Office Equipment & Supplies
I have an HP 2575 All-In-One and it has been showing an error message on the screen recently. The message says there is an ink cartridge problem. I have tried everything to fix this, but right now, the problem is that I urgently need to scan a document to my computer. Is there any way to get the printer to do this? It won't seem to let me, but I'm hoping there is some way around the problem.
  • 51 Answers
SOURCE: INK CARTRIDGE PROBLEM Remove and check
Take the cartridge out and rub the contacts with a piece of damp tissue paper and try again.
Check the contacts in the printer itself where the cartridge sits. If there is any damage or pin hole on the white ribbon with the gold contacts on it then the printer is unrepairable but it sounds like a cartridge problem. Try changing the cartridge as well
Posted on Jun 14, 2008
  • 521 Answers
SOURCE: my hp photosmart 2575 says
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Posted on Aug 14, 2008
SOURCE: MX700 Will not scan with an empty ink cartidge?!
I just came up with the same problem. But if you keep pressing the right most button (the red one) for 5 seconds the message "replace ink cartridge" disappears and then you can use it as a scanner.
Posted on Mar 22, 2009
anujbhatt
  • 66 Answers
SOURCE: I have an HP Photosmart 2575 All-In_One Printer,
if it is XP, then click on start , then run , in run type wiaacmgr.exe and hit enter, try to scan.
In vista and windows 7 , replace run with start search box.
Posted on Apr 10, 2010
  • 111 Answers
SOURCE: HP Photosmart 2575 printer - ink cartridge problem
Is this a Hp cartridge or a cheaper brand?
I got this error myself too with cheaper cartridges.
You cal solvo this error by buying the original Hp cartridges
Posted on Apr 13, 2010
I get different ink cartridge numbers for my hp2575, which one will work?
HP 98 black cartridge, HP 95 Colored cartridge are the standard ink for Hp 2575.
press the helpful button
Jan 05, 2016 | HP Photosmart 2575 All-In-One Printer,...
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
Error Code 0xc1ab0001 What do I do?
The "Oxc1ab" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Jul 05, 2010 | HP Photosmart 2575 All-In-One InkJet...
Printer (HP deskjet F4180) showing E and color
This means that there is issue with the Ink Cartridges.
Please remove and re-insert the cartridges.
Check the expiration date on them. Also make sure that you are using genuine HP Cartridges, not refilled or Remanufactured.
If the issue still persists, please replace the ink cartridges.
Jun 02, 2010 | HP Photosmart 2575 All-In-One Printer,...
Mar 21, 2010 | HP Photosmart 2575 All-In-One InkJet...
HP 2575 printer - paper jam message
Resetting the product may help with some false error messages. Press power button to turn printer off, unplug the power cord, wait a few seconds, plug it back in, press power button to turn printer back on. Any luck?
Dec 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Color Ink Cartridge Problem
Unplug the printer, and leave it unplugged for 5-10 minutes. Then if the printer is still complaining about the color cartridge when you turn it back on, then replace the print cartridge.
David
Dec 04, 2008 | HP Photosmart 2575 All-In-One InkJet...
Hp photosmart printer
go here and search
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&qry=error+0xb82e4cc4&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&submit.x=0&submit.y=0&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&contextual_lname=&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&search=0
Dec 12, 2007 | HP Photosmart 2575 All-In-One InkJet...
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
