Question about Dryers
The dryer isn't getting hot - Dryers
  • Sebastian923 Nov 30, 2008
    My LG gas dryer (dLG 2532w) heats up a little for the first minute or two but then cools off and doesn't heat any more. Also, the "check filter" light goes on when I turn on the power but shuts off when i select and start a cycle. Any Ideas?
  • 116 Answers
IF GAS RE[L/ THERMAL FUSE IF ELECTRIC REPL HI LIMIT AND SAFETY THERMOSTATS
Posted on Nov 30, 2008
2 Suggested Answers
SOURCE: My dryer is turning but it isn't getting hot? What
dryer element not getting hot .possibly only 110 volts instead of the needed 220volts ...maybe a bad breaker in fuse box
Posted on Nov 29, 2011
Bosch axxis dryer isn't drying well
what is your model number is then we can get started then
Jan 31, 2013 | Bosch Axxis Condenser Dryer- White
Here's a good troubleshooting article on them:
http://www.ehow.com/way_5389575_troubleshooting-kenmore-series-dryer.html
Keep in mind, it is an older dryer, but that series is known for being really good. If the article doesn't check out, I would suggest calling in a technician as it's possible something got damaged in the move/
Dec 31, 2012 | Kenmore Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Nov 29, 2011 | Kenmore Dryers
The dryer isn't drying. The top an the control panel are very hot to the touch.
Hello Rodney.
What the most probable trouble with the dryer making it very hot to the touch while at the same time not drying is a poor air flow problem. That could a be a broken blower wheel,a blocked or restricted vent.
GENE
Nov 12, 2011 | Dryers
I changed the fuse and the dryer was hot at first but isn't getting hot again. What else can I do?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Dryers
The dryer gets hot, but has a burning smell and this load isn't drying?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 14, 2011 | Dryers
Dryer will get hot but will not dry clothes
If the dryer gets hot, but not drying the clothes my first question would be if the drum is turning or not. If not then I would check the belt and make sure it isn't busted. Then I would check to make sure that your exhause hose is not clogged up. If so clean out.
But if that isn't the problem then I would check the blower assembly.
Aug 07, 2011 | Dryers
Clothes are real hot to the touch
sounds like you have a venting problem,, check for clogs or blockage in the vent pipe,, and also at the exit from the house to be sure the vent cover flows freely and isn't smashed down. check inside this vent to be sure the flap inside of it moves freely and isn't stuck,, Normally when clothes get hot to the touch its caused by the clothes heating up to dry and the moisture isn't allowed to be vented out
May 24, 2011 | Whirlpool Dryers
Dryer shuts off when it gets hot but restarts
1.Remove your exhaust duck on the back of the dryer and clean it.
2.Make sure your exhaust going to the outside vent isn,t clog.
3.Check thermostat.
Mar 07, 2010 | Dryers
Dryers Logo
310 people viewed this question
Top Dryers Experts
Marvin
Marvin
