Question about Panasonic NV-GS15 Mini DV Digital Camcorder
"Push the reset switch"
Whenever power is turned on I am getting a message in LCD panel flashes the message stating " Push the reset switch" Even if I push the reset switch and turn the camera off & on it back again the same message is coming back again & again. I even tried it with different batteries & direct power but the results are same. I removed the inserted tape & tried it with new casset but no luck. With this message flashing I can not operate anything. Is this due to exposure to condensation or mechanical defect? User manual does not specify this & does not even tell what causes this message coming. Can you please help me with this matter? Thanks, Nagaraj
  • 4 more comments
  • RonnieG Nov 08, 2007
    I have the same issue.
    when changing the tape, or after a function (ie, after rewinding the tape, etc.) Just to playback video or record, I have to do the "press the reset switch" dance for about 10-20 minutes. Eventually, however, it works... but by then, the event that I wanted to record is over.
  • not a tech Dec 01, 2007
    Yes I had the problem and it finished up all them mechanics of the tape would not work. Had it repaired at a cost of $250 and now it is doing it again, would love an answer
  • Anonymous Dec 06, 2007
    same problen as above
  • Anonymous Dec 07, 2007
    Same Problem
    I found through trial and error that the tape was coming unseated in the case. I eject the tape and reinsert it to clear the problem (sometimes takes several tries to get the tape to eject) Good Luck
  • dwaramswamy Dec 27, 2007
    I AM UNABLE TO PLAYBACK THE VIDEO, EVEN I AM NOT ABLE TO RECORD SOMETIMES. MOSTLY I GET THE MESSAGE"PRESS THE RESET BUTTON". I DON NOT KNOW WHERE THAT RESET SWITCH IS OR HOW TO DO THAT???
    PLEASE HELP. MOST URGENT PLEASE.
    SWAMY
  • redryder4 Jan 21, 2008
    Looks like there are no fixes as of yet... I too will turn on the camera only to here those horrid beeps and the dreaded "push the reset button" message. This was remedied by turning power off/on. As of late, more specifically, on my son's 3rd birthday. I must have reset the thing 25 times! I missed footage I'll never be able to replace.
    Sometimes when powering on, I feel the cassette trying to eject (while the door is closed! This is soon followed by the "push the reset button" message.
    I too have had the tape (ribbon) pull out from the cassette.
    The problem is happening much more frequently now.
    I think I'll invest in a new camera before spending money to repair this one. A friend has a similar model panasonic and was experiencing the same problems. He took it in for repair and is again having problem..
    I hate bad mouthing panasonic, but I'd steer clear from this generation of Pani's.
    New Friend:
  • 4 Answers
I had the same problem with the 'push the rest button' on the display after the tape mechanism jammed up against the tape compartment cover. I figured there was probably a mechanical error, possibly a switch. I dissassembled the camcorder and found the tape compartment cover switch was sticking. Here's how to fix it with some photos to illustrate:
1. Open the tape compartment door and remove the screws in the small plastic cover (fig. 1). Remember to look a which screw came from each hole as they are all different.
2. Remove the plastic part from above the tape mechanism (fig. 2)
3. Remove the screw above the front grip belt mount (fig. 3)
4. Remove the screw above the mic (fig. 4)
5. Remove the battery and take out the screw at the top left under the viewfinder (fig. 5)
6. Take out the screws under the LCD monitor (fig. 6)
7. Remove the two screws from the front underside of the camera body (fig. 7)
8. Now you can slide the front of the camera, together with the curved aluminium top section away from the main body of the camera (fig. 8)
9. It is possible to reach the switch with the front moved forward slightly, but it is possible to take the front off entirely by removing the wiring ribbon with the green tab (fig. 9)
10. Clean the brown switch at the bottom left of the exposed camera front with a soft brush/air (fig. 10 )
11. Reassembly is the reverse of the above procedure.
Hopefully this will mean no more frustration with the 'press reset button' screen.steviedeee_0.jpgsteviedeee_1.jpgsteviedeee_3.jpgsteviedeee_4.jpgsteviedeee_6.jpgsteviedeee_7.jpgsteviedeee_8.jpg
Posted on Jan 16, 2011
I have the same problem with my new Panasonic Camcorder, and found out the problem came from using a mini DV tape rewinder to rewind the tapes (all brand new). It looks that the camcorder does not read the length after the rewinding. I spent an hour to forword the tape to its end by a pencil then the error is gone. Not a good solution but there is a reason.
Posted on Dec 26, 2007
    Problem Solver:
  • 11 Answers
I had the same problem, I took it to panasnic and had to replace the tape carriage mechanism, fixed the problem but was EXPENSIVE (but less than a new camera so decided to do it).
Technician said lack of use causes the carriage to seize up (I barely use my camera) he said store with tape out of camera, and once a week play / record for a few minutes to keep the carriage in good working order.
Posted on Jun 10, 2008
  • 3 Answers
I notice this happens right after changing the tape. it's a PITA, but make sure the doors all close tightly is my best suggestion.
Posted on Nov 09, 2007
I was having the same problem and now, the power has stopped coming 'ON', neither the casette comes out. Need urgent help Anant
Posted on Jan 25, 2007
SOURCE:
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Sony cybershot dsw50 error flashing e;91;01 flash not working at all
E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work.
Camera needs Flash Circuit replacement and part number is as follows...
A-1166-208-A ST-133 BOARD, COMPLETE
Above said Flash Circuit is available in Part Store.
Good Luck.
Nov 27, 2008 | Cameras
My dell E207WFP lcd first flickers and then flashes red,green, blue, black, white and green color after some time of use ...
some of the capacitors are blown on the boards that are inside the unit
the lcd is on its way out. I recomend when getting a new one to turn it off whenever you are not at your pc. even though it goes to sleep after a while of no activity there is still a current going through the unit because if you move the mouse it will wake up. I know this because I was a bench technician and I have done board level repairs. These capacitors have anywhere from a 20000 to 40000 hour life span so when not at your pc turn it off!
Nov 23, 2012 | Dell E207WFP 20" Widescreen Flat Panel LCD...
When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
Please reset the Printer by following these steps:
Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
Release "Stop/Reset" while holding down the "Power" button.
Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
Push the "Power" button, then lift the MX310 cover open.
Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Feb 27, 2011 | Canon MX310 Office All-In-One Printer
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Whenever i turn on my sony MHC-VX333 mini hi fi it flashes the message "push power protect"
when it display push power,this indicate an instruction to push the power button. please do so
May 17, 2010 | Electronics - Others
While I was using my hannspree hf289h, it just turned off and won't power up anymore. Is it broken, or can I reset it or something?
christerfred, I would think that if it TURNED OFF all by itself, and no matter how many times you push the on/off switch it remains in the OFF state, I certainly think it's BROKE. In fact I think that the "switch-mode-power-supply" may be in permanent SHUTDOWN mode. Here is a clue! When strange things happen to an LCD display, the first place to look is the power supply, be it a SMPS that lives on the floor or resides inside the plastic case of the monitor. I have worked on a few LCD displays and repaired a few of them. But I have never come across a magical "let it work" reset button. If Hannspree won't do anything in the way of warranty work, then go watch some of the longer video clips of "LCD monitor disassembly" and "LCD repair" @ YOUTUBE just so that you will know what is up with all the LCD monitors (all brands) that now have BLACK and LIFELESS lcd panels. Also do a visit to www.ccl-la.com/badcaps.htm and www.badcaps.net for additional info. You will also need to do a search for the "LCD flashlight test" to evaluate the state of your Hannspree SMPS. After doing the above, get back here and tell me what you want to do. If you feel that the information received at fixya was helpful, please rate this response at fixya. I'm louie12fix on fixya bye for now.
Oct 12, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Need front panel pin connection for HD led ,power led and switches for AMD Duron mother board
Hello there
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM 3051k - Adobe PDF - View as html Supports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Sep 13, 2009 | AMD DURON,1.2GHZ,1200MHZ, FSB200Mhz ( OEM...
Sharp Aquos LC-52D64U Won't Turn On
I have fixed many sharp lcd tv's with a reset. If one appears to have no defects like bad capacitors, fried inverters, broken panel, ect. and the power light is flashing steady or not on at all a reset may help. There is a lot of bad information regarding the procedure though. The correct procedure is to unplug the tv, hold volume down and channel up at the same time and plug it in. Release those buttons then push the power button. Did it start? Great! I have no idea why so many seem to need this. If there truly is a problem this will only work temporarily or even momentarily but many will be fixed for good.
Apr 10, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
ASTAR LCD TV 32'' won't turn on any more.
I have cable connected to my astar tv. I have the same problem whenever I turn my tv off of not getting the tv to come back on. What works for me is 1. Reset power- turning off both the tv
Nov 17, 2008 | Astar LTV-3201 32 in. LCD Television
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
2,266 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
