Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba 42in 42H83 flicker
The red green and blue bulbs flicker instead of staying on steady making a scrambled picture. any ideas?
5 Suggested Answers
falspet
  • 438 Answers
SOURCE: control board say not availible when any button is
this may be due to a stuck on mode select button control, are you going to try to repair yourself ? do you have a shop manual ? let me know
Posted on Jan 31, 2010
  • 171 Answers
SOURCE: Hi: My Toshiba starting showing the symptoms (as
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
Posted on Sep 21, 2010
SD Tech
  • 14553 Answers
SOURCE: My Toshiba 42H83 has a
ok, you are talking about lines in the picture, it started where it would clear up after a few minutes but now it will slowly take longer?
I know what is wrong.
SD TECH
Posted on Oct 22, 2010
hardrocko
  • 1476 Answers
SOURCE: Toshiba 42h83.... The blue convergence will not
bmarino18,
Initially I would have told you to replace the convergence ICs but after reading your post carefully I think you could have a problem with the convergence box. The lines can only be bent/curved for two reasons. One - the yokes are bad causing an undue strain on the power supply and not being able to correct the problem. Two - the convergence box/board is bad and is not holding the settings causing the curve you see. I cannot tell you which problem you have. You wil have to determine this. I do have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which may be helpful.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Dec 08, 2010
Toshiba 150r6f color blue is missing
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
The transistor that your friend told you, can be located at the CRT base card [Video Output] itself.
Mar 01, 2014 | Televison & Video
Hi: My Toshiba starting showing the symptoms (as it has in the past) that it needed a new bulb. The red light comes on, is steady, but then the green light comes on and flickers. I have now put in 2 new...
Sep 21, 2010 | Toshiba 62HM95 62" DLP HDTV
Convergence setup for toshiba 42in projection
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 06, 2010 | Toshiba 42H83 42" Rear Projection...
Control board say not availible when any button is pressed, only shows av1 picture and picture is scrambled, toshiba 42h83 modle rear projection tv
Jan 30, 2010 | Toshiba 42H83 42" Rear Projection...
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 57HX81: Green works but Blue and Red seem to be out.
Do you still have reds? Is the image still clear though discolored? If so you ought to replace the blue bulb which has most likely failed. The part no for the 57HX81 model blue CRT bulb is TOSHIBA     23008753.
Jun 11, 2009 | Toshiba 57HX81 57" Rear Projection...
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Red spot in the middle of the screen
You most likely have a burn in on the surface of one of the picture tubes. What you need to do to confirm this, would be to take off the front screen, and with the set turned on, look directly into each one of the lenses, and see if you see a mark on the green or the blue tube. if this is the case, and I am pretty sure it is, the picture tube will need to be replaced, but this set is not a young thing, as the green faint lines is most likely a bad capacitor in the screen drive circuit. If the picture tube is indeed burned on the surface, most likely be better off buying a new TV set. Good Luck
Jun 25, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
