Question about Dehumidifiers
Danby Dehumidifier I have a danby 58 pint dehumidifer that is diplaying E1 and the romm humidity is displaying 25%. What is going on. It is less the 1 year old Danby 65 pint dehumidifier stopped working, Code E1 on power up. Does not appear to function although FAN stays on when in E1 mode for a while and then E1 stays on solidly with no activity. Dehumidifier is less than 6 months old.
2 Suggested Answers
SOURCE: Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Posted on Jul 20, 2009
I have a danby dehumidifer model number DDR6011R It keeps saying the humidity is only 30..(Which I know it's higher) so the compressor isn't kicking on. Help??
It sounds like the humidistat sensor failed on the unit. You'll need to replace that sensor to be able to get the unit operational again
Sep 10, 2016 | Danby Dehumidifiers
I have a Danby which has the feature for heat on the left-hand side. I just bought it a month ago, but can't lay my hands on the instruction book right now. Can you tell me the proper procedure for...
Lori, the Danby Humidifier, Model # DDR2504 does not have a heating function. It's just a 25 pint dehumidifier. In fact, there are no Danby Dehumidifiers that have a heating function.
By, chance do you have Multifunction Air Conditioning unit, rather than a dehumidifier? If so, please provide the correct model number.
Thanks for choosing FixYa.
Sep 11, 2011 | Danby DDR2504 Dehumidifier
The Danby Millennium Dehumidifer goes not condense any more. Have unpluged the unit, cleaned all of the filters. Is there a way to reset the unit from the controls?
If you unplugged the heater for 12-15 minutes, after turning OFF the Master On/OFF Switch, the electronics should reset themselves. Also, be sure that you don't have the humidity level set to high. Anything above 60% wont' extract any moisture to speak of. If your unit doesn't have an LED display, set the unit on Minimum.
Hope this helps you. Please let me know. Thanks.
May 17, 2011 | Danby DDR401 Dehumidifier
Lost owners manual ...looking for 1 online to download..model #DDR586R
Your model may have been discontinued, as it doesn't show up on any list I have. However, you can call Danby Customer Service 800-263-2629 and they can provide one for you.
Mar 11, 2011 | Danby DDR586R Dehumidifier - 58 Pints...
The machine is not sucking out moisture why
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 22, 2010 | Danby DDR586R Dehumidifier - 58 Pints...
Dehumidifier runs but does not remove moisture.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 02, 2010 | Danby DDR6588EE Dehumidifier
E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | Danby DDR451 Dehumidifier
Fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Humidty reading remains at 84%
Dehumidifiers are generally a very simple appliance, however a humidistat is one of those items a person tends to rely on to provide feedback. You may want to remove the grille area where the humidistat is mounted and inspect for foreign material in the way of the sensor. If nothing foreign is detected then you should replace the humidistat.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 29, 2008 | Danby DDR586R Dehumidifier - 58 Pints...
Dehumidifiers Logo
99 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
