Question about Canon PowerShot S3 IS Digital Camera
SD message error
I'm using a 1gb Imation on my Canon Power Shot S3 IS. When shutter button is pressed down a "memory card error" is shown. Also, the playback mode give a small pciture with the message unindentified image,
What did can be done?
  • 4,806 Answers
Go into the settings and "format" the sd card, that should solve your problem
kind regards and please don't forget to rate us
Posted on Nov 30, 2008
I PUT THE WRONG CHIP ON MY CAMERA "POWER SHOT S3
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
I own the Canon Power Shot S3IS. What is the largest SD card I can use in the camera;32GB? Thanks.
The largest SD card you can use is 2GB, but that's only because SD cards only go up to 2GB. You can also use SDHC cards from 4GB to 32GB. You cannot use larger SDXC cards.
Apr 05, 2010 | Canon PowerShot S3 IS Digital Camera
Canon Power Shot A480 memory card error showing on screen I have checked side locked button
If it's a brand new card, it needs to be formatted with the camera. If it's been used before, the files may have been corrupted when plugged into your (or another) computer.
Nov 08, 2009 | Canon PowerShot A480 Digital Camera
I have a canon power shot s3is and when i put a sd card into it it says memory card error. i've tried a number of other sd cards it seems not to read any card. just randomly started.
It is likely that an internal metal contact (one or several ones) inside the sdcard reader are bent, or damaged.
You will need to have your camera reviewed by a qualified technician to have it repaired, since it requires open the camera and evaluate the sd card reader mechanism.
Best regards,
Jul 11, 2009 | Canon PowerShot S3 IS Digital Camera
New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
Jan 09, 2009 | Canon PowerShot SD600 Digital Camera
Hi, I have a Canon Power Shot S2 IS 5.0 megapixels that was working fine until one day I changed the memory card from 512MB to a 1GB. Now every time I turn the camera on and try to take a picture, a...
Its possible that there may be an error on the camera try to reset the camera by
1. Turn the mode lever to the camera or play button
2. Press and hold the MENU button for more than 5 seconds.
3, The message "reset settings to default?" appears
4. Use teh arrow buttons to selelct ok. then press the SET button.
5. It should then reset the camera.
AFter doing that and the problem is still there. Format the memory card using the camera.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 06, 2008 | Canon Cameras
Sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Jul 28, 2008 | Canon PowerShot S3 IS Digital Camera
Memory Card
chances are its the size of the pictures the camera is set to take,you will have to make them smaller, and lower quality to raise the amount of pictures you can take.The instructions on how to do that should be in the manual, or you can try the 1 i found on their site.
Changing the Resolution and Compression
1. With the camera power on, press the <FUNC./SET> button.
070.gif 2. In the Function menu select L* or 295.gifusing the 021.gifor 026.gif button.
a550rescomp.gif * The current setting is displayed.
3. Select the resolution or compression you wish to set using the 028.gifor 023.gif button.
You can shoot the image right after selecting settings by pressing the shutter button. This screen will appear again, once the image is shot.
6. Press the <FUNC./SET> button.
7. Shoot the image.
i hope that helps,later you might want to invest in a bigger memory card, 16mb is very small.Id go for a 512mb or a 1gb SD memory card ,then you'll be able to take more larger quality pictures.
May 25, 2008 | Canon PowerShot A560 Digital Camera
Samsung D600 memory card format
When i insert memory card it says not allowed
Mar 03, 2008 | Samsung SGH-D600 Cellular Phone
Canon PowerShot S3 IS Digital Camera Logo
106 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
