Question about Refrigerators
My Sear's Kenmore Elite refrigerator is not cooling
The light is on, the motor is running, and the freezer is working (although ice maker is condensating). But the fridge is not cooling at all....no air comes out of the air thing when I depress the door closed  button. Last time this happened, a repairman told us it was a grate of some sort stuck in a closed position, and that we could open it ourselves......but I don't remember where that place is! Please help!
    Top Expert:
  • Refrigerators Master
  • 46,031 Answers
Check the fan at the bottom.
Posted on Jul 20, 2017
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
catriver
  • 878 Answers
SOURCE: Freezer works fine refridgerator does not
anan, I think your display is giving you a code on these LG. See if you can find the tech sheet behind the toe panel. On your display panel from memory, 3 led's lit from the left means a failed defrost thermistor. This could be the reason you are frosting up and restricting the air flow. There is a main board in back that you can ohm out the thermistors. Connector 4, the two bright orange wires #5 and 6, should ohm at 19K ohms at 50 degrees. Now Im doing this from memory, if you can find your tech sheet, it will give you precise information. Catriver.
Posted on Jun 14, 2007
  • 3 Answers
SOURCE: Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Posted on Aug 20, 2007
  • 14 Answers
SOURCE: Amana arb2557cw condenser coils freezing, fridge not cooling
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Posted on Jul 31, 2009
blueextc3221
  • 15935 Answers
SOURCE: MY ICE MAKER WON'T WORK
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
How can I get my Kenmore Refrigerator Model 501-7835# Ice maker to work. Stopped working.
Perhaps you can call your local Sear store and ask them what course of action you should follow.
Someone will need to take the refrigerator ice maker all apart and find the part that is broken or out of adjustment.
God bless your efforts.
Jan 08, 2016 | Kenmore Refrigerators
Bottom freezer works top isn't cooling and noisy
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is working, fridge is not cooling, currently at about 58*. Ice maker is not hooked up, but appeared turned on.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The bottom freezer of my Kenmore Refrigerator works fine but the top refrigerator compartment no longer cools? Thanks
All the cooling happens in the freezer.The refer section relys on a fan to blow cool air into it.When you open the freezer you should hear a fan running.If you hear the fan running, close the freezer door and open the refer door. Look for the vent/area where the air comes in.Put your hand in front of it.If little or no air is coming out it could be a sign of an icing/defrost problem restricting the air to the refer section.
It will take a tech with the right tools to find the exact problem.
If the fan is not running you will have to unplug the unit and remove the back of the freezer section from the inside and make sure ice is not keeping it from turning.If it is free of ice then replace the fan motor.
Mar 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The refrigerator is not working
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jul 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
