Question about JVC KD-LH2000 CD Player
Lighting problem JVC KD-LH2000
Hi i have a JVC kdlh2000 car stereo which ive owned for bout 3 years about 2 weeks ago when i jumped in my car i turned it on but there was no lighting or anything on the faceplate it was all black the stereo still works but i cant use any buttons on the faceplate so i cant turn it up or change the song etc everything else works fine the headdeck cost me $1000 new-zealand$ which was well worth it as it has great sound so if any-one can help me i would be very grateful
If you still have this one, I just fixed mine with essentially the same problem by doing a thorough cleaning of the contacts with a Q-tip and rubbing alcohol. On the stereo side's contacts you'll need to stretch some of the cotton out on the q-tip so it will fit between the plastic ribs.
Posted on Jan 19, 2008
    Novelist:
    Champion:
  • 219 Answers
If your unit is a "flip face" design then I would suspect that the flat ribbon cable that goes between the flip face and the main board has lost at least one of the leads and that the cable needs to be replaced. Try Partstore.com for a replacement. Good luck.
Posted on Jan 21, 2007
SOURCE:
How do i set the time on my car stereo it's a jvc kd-r200
Hold the SEL button to bring up the PSM menu, use up/down to select CLOCK H for hour or CLOCK M for minute, turn the knob to adjust, and press SEL to set.
Full details are on page 3 of the manual.
Mar 10, 2012 | JVC KD-R200 Car CD/ MP3 Player
Trying to set my clock on my jvc kd lh 2000 but cant same to find out how
Press the Sel button (the center of the control ring) for more than 2 seconds until a PSM control category appears in the display. Use the up/down arrows to navigate to Clock. Then press the fast forward or fast reverse button to select Clock Hr. Then turn the control knob clockwise to add to the current value or counterclockwise to decrease the value to the desired hour. Then use the fast forward or fast reverse to select Clock Min. Repeat turning the control knob to set the Minutes. Press Select again to save the setting.
The manual is here: http://books.jvc.com/booklist.asp?Model=KD-LH2000 . The clock set procedure is on page 29.
I hope this helps.
(In a few cars, I've seen the controls end up reversed. If it doesn't respond as above, try swapping the order of the up/down and fast forward/reverse buttons to navigate the menu properly.)
Nov 22, 2010 | JVC KD-LH2000 CD Player
Car stereo JVC KD-PDR40 lost manual can't set clock?
hi my jvc kd-pdr40 cd player keeps resetting the sound to basic with no bass everytime i turn it off
Sep 26, 2009 | JVC KD-PDR30 CD Player
Setting the time on car stereo/cd player
Changing the general settings
(PSM)
You can change the items listed on the next page
by using the PSM (Preferred Setting Mode) control.
• The PSM items are grouped into five
categories—“Disp (display),” “Clock,” “Tuner,”
“Color,” and “Audio.”
Basic Procedure
1 Press and hold SEL (select) for more
than 2 seconds so that one of the PSM
items appears on the display.
(See page 23.)
The currently selected
category is shown on the
left side of the display.
2 Press 5 (up) or ∞ (down) repeatedly
until your desired PSM category
appears on the left side of the
display.
3 Select the PSM item you want to
adjust.
4 Adjust the PSM item selected.
5 Repeat steps 2 to 4 to adjust the other
PSM items if necessary.
6 Finish the setting.
To set clock—Clock Hr, Clock Min
You can set the clock using the PSM control.
1 Press and hold SEL (select) for more than 2
seconds so that one of the PSM items appears
on the display.
2 Press 5 or ∞ repeatedly until “Clock” is selected
as the PSM category (it is shown on the left side
of the display).
3 Press ¢ or 4 to select “Clock Hr
(hour).”
4 Turn the control dial to adjust the hour.
5 Press ¢ or 4 to select “Clock Min
(minute).”
6 Turn the control dial to adjust the minute.
Nov 04, 2008 | JVC KD-G720 CD Player
Help
Hi, Normally, your JVC Car Stereo will not allow direct connection to an Apple iPod. However, there are several aftermarket interface adaptor that will allow you to do so: 1. Connect the iPod to a JVC KS-PD100 which in turn is connected to the CD changer jack of the KD-G720 (rear of the unit). Set the stereo to CD changer external input setting and you're ready to go; 2. Connect the iPod to an FM Transmitter such as the Griffin iTrip (w/ Dock connector) which in turn will broadcast the IPod music as an FM signal. Operating the KD-G720 on FM radio setting will receive the IPod's broadcast music. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | JVC KD-G720 CD Player
JVC KD-LH2000 CD Player Logo
161 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
