Question about Hardware & Accessories
Installation of Seat Covers
How do a remove the recline levers for my 1987 Toyota Celica? Also, how do I remove the round seat adjustment lever without a screw in the middle?
    Problem Solver:
  • 5 Answers
Look for a :
"c" clip at the base of the lever real close to the fabric,and/or a set screw on the side shaft
Posted on Jul 19, 2009
How can we adjust driver's seat so it isn't reclined?
If the lever that controls reclining does not work, some previous owner probably broke the mechanism.
Apr 07, 2016 | 1990 Oldsmobile Eighty Eight
1998 explorer passenger side seat lever / diagram
Find a seat at a junk yard. No one sells those parts. Dealers will only sell you a new seat. You spend 3 hours pull the covers and parts off the seat only to find out, You can't fix it.
Aug 30, 2015 | 1998 Ford Explorer
Pontiac g6 seat recline lever won't work anymore
remove seat(s) and check for obstruction in the mechanism path. You'll need a big Torx bit.
Mar 22, 2014 | 2007 Pontiac G6
2004 cavalier driver seat reclining lever broke off
to determine if lever just broke and seat works OK, actuate seat with vice grips to verify operation
Feb 27, 2014 | 2004 Chevrolet Cavalier
Ait bag warning light on, plus passenger seat doesnt fold forward correctly and difficult to get back in the correct position after letting passengers into the rear. 2002 cooper. thanks
Regarding the passenger seat, to allow someone into the back seat, push the seat back lever DOWN. This will flip the back of the seat forward and allow the seat to slide forward. Simply push firmly on the seat back (no need to touch the lever) and it will return to its original position.
If you pull the seat back lever UP, you can adjust the recline angle of the seat back. Pulling the lever UP will also let you fold the seat and slide it forward, however, it will not return to its original position.
Sorry, cannot solve your airbag question.
Mar 11, 2011 | 2002 Mini Cooper
How do i remove the front seats of a 1998 Pontiac Grand Prix?
On W-Body vehicles, the front seats are secured to the floorpan by two front hook attachments and two rear bolts installed to nuts welded to the floorpan.
The manually operated two-way front adjusters provides only fore and aft movement of the seat. When the seat adjuster handle located on the front seat is pulled up, the seat adjusters unlock, permitting travel of the seat. When the seat is in the desired position and the seat adjuster handle is released, the seat locks in place.
A power operated six-way seat adjuster is available. The adjusters are activated by three 12 volt, reversible, permanent magnet motors with a built-in circuit breaker. The motors are energized by a switch bolted on the seat side panel.
The three motors drive the front seat and rear vertical actuators and a horizontal actuator. When the adjusters reach the limit of travel, torque is absorbed through the rubber mounted grommets located between the motor and the support. An overload relay is provided in the circuit and will open should excessive stall be applied.
The optional 60/40 split bench front seats have seat back head restraints on the driver's and passenger's seat back. The head restraints are designed so they cannot be removed from the seat back without first inserting a small rounded tool inside the head restraint support tube to release the locking tab. The 60/40 split bench seat is equipped with a reclining mechanism on both the driver's and passenger's side. The recliner lever is located on the outboard side of the spring cushion. When the lever is pulled upward, the spring loaded dual linear reclining unit located in the cushion frame is released, allowing the seat back to be pushed rearward or allowing the spring loaded reclining unit to bring the seat back forward.
Bucket seats are equipped with manual reclining mechanisms. An optional six-way power seat adjuster is available. Some bucket seats are equipped with inertia seat back locks. This system allows the seat back to fold forward without requiring the occupant to release a locking lever or access to the rear seat area. During a sudden stop or deceleration, or if the front of the vehicle is nose down, the inertia system of the seat back lock will engage, holding the seat back in its rest position. A release lever is provided to allow manual release of the seat back lock when the vehicle is in the nose down position. The release lever is located at the lower rear outboard corner of the seat back.
Some W-Body vehicles (notably Pontiac coupes) have passenger front seats equipped with an E-Z Entry device. This is actuated, in an unoccupied seat, by completely folding the seat back forward disengaging the adjuster, and sliding the front seat forward to gain access to the rear seat area. To return the seat to its normal position, return the seat back to its rest position, and slide the entire seat rearward, engaging the adjuster.
W-Body rear seats are available in several styles including a rear seat with an integral child restraint device.
Sep 01, 2009 | 1998 Pontiac Grand Prix
The reclining lever for my has broke off cant recline the seat what do i do to make the back of the seat to recline
well lets not start with visegips .
the lever needs to be removed by removing the screw and removing the lever.
go to the dealer to get the new lever and put it on.
Jun 12, 2009 | 1999 Ford Ranger SuperCab
Recliner?
usually not. seat is electric and adjusts to extent allowed by that. Passenger seat has a back release on it though.
Apr 07, 2009 | 1986 Chrysler Fifth Avenue
Passenger seat 2006 vw jetta
I don't remember which knob adjusts that area for the seat but if it's like the one I used to own, much older model, it had a turn knob on the side of the back rest that you had to actually turn to get it to do that recline position. Look at your seat and see if it has a large knob on the side of the back rest and if it does, turn it until the seat reclines. I think it does. but not sure. if it doesn't then look on the side of the seat by the door for a lever there to see if that is the lever to make the seat recline. Vw has more than one knob most of the time. you can also check your owner's manual for seat adjusting and it should tell you something.
Aug 08, 2008 | 2003 Volkswagen Jetta TDI
Hardware & Accessories Logo
73 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
