My computer will turn on - the windows bar shows and then the screen turns black. How can I fix this problem. I had early erased some programs from my computer but I didn't think that this should cause any problems.
  • Frank Doll
    Frank Doll May 11, 2010
    When the bar comes on the screen, this means the kernal for Windows Operating is loading. If it completes and than hangs the problem is in the Ini files and/or registry. This could be caused by anything from a bad registry entry to a bad or inproper driver load. If you just updated a driver such as a video or sound driver. If you just added new software the problem can happen. If you removed a device and it's driver the problem can occur. A trogan Virus can do this. So, as you see it's hard to resolve this issue without more info. Try to Boot in Safe Mode using the F8 or F5 key just before the bar starts, a screen will ask you how to boot. Select safe mode. If the machine does boot to the desktop, your problem is now usually a driver problem. A Trogan could still be loading into memory before Windows boots and cause the issue though. This is all the help I can offer at this time without more exact info and history.
  • 903 Answers
If you leave the computer it will eventually boot up, but something is causing the delay. Why not try booting in safe mode by pressing F8 as it boots and restore it to an earlier time when you know everything was working okay. Sometimes when programs are uninstalled they can take files that other programs rely on. Try restoring by pressing F8 on boot entering safe mode, go to start>programs>accessories>system tool>system restore and choose a date when you know that the computer was working okay with no problems.
I hope this helps
Posted on Nov 30, 2008
How can i fix igdpmd64.sys erorr in windows 7?
KB2670838, after this update, some HP and Dell notebooks are having Bluescreen
and black bar on Internet Explorer on right of its window. When they click that black
bar BSOD pops and shuts down computer.
How to FIX:
Open Control Panel > Programs > Uninstall Programs > View Installed Updates > Find
and uninstall KB2670838 > Restart computer > Open Windows Update > Check for Updates > Under optional downloads find KB2670838 right click and HIDE it.
That's it until Microsoft releases a permanent fix.
Note: This update is having interference with onboardly manufactured AMD Graphics of mentioned notebook models.
Feb 28, 2013 | HP Pavilion dv6000z Notebook
I tried to factory restore my laptop and a message saying it cant install windows to my computer...what does that mean and how do I fix it?
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Hope this helps don
Feb 25, 2011 | Acer Computers & Internet
I'm trying to change the screen resolution while running windows 7 because I have no desktop showing on my monitor
Firstly, there appears to be many causes of the black screen issue. The symptoms are very distinctive and troublesome. After starting your Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system appears normal. However, after logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see.
If you have these symptoms you can safely try our free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below: 1) Restart your PC 2) Logon and wait for the black screen to appear 3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this) 4) Press the CTRL, ALT and DEL keys simultaneously 5) When prompted, Click Start Task Manager 6) In Task Manager Click on the Application Tab 7) Next Click New Task 8) Now enter the command: "C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com/download.asp?GRAB=BLACKSCREENFIX" Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it. 9) Click OK and your browser should start up and begin the download process 10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue. 11) Now restart your PC and the black screen problem will hopefully be gone.
Oct 11, 2010 | Computers & Internet
When my computer starts up after the windows logo loading screen the screen turns black and then my keyboard and mouse stop responding and the screen stays black thats it
Press F8 key after post boot screen and before windows booting, dos screen will come from there select safe mede booting, computer will boot in safe mode
1) Click On start
2) Go to All programs
3) Go to Accessories
4) Go to System Tools
5) Select system restore
Sytem restore window will come there you will select restore my computer to the earlier time, you will get calender on the screen there you have select any highlighted previous date
After restart your computer will be ok.
Apr 01, 2010 | ASUS P4B533-VM Motherboard
The windows start up shows and then it shows the scan bar and then a black screen and nothing else. How do I fix this?
Reboot the computer and keep hitting F8 to enter the recovery screen. Boot into Safe mode, and run system restore (programs-->Accessories-->system tools). Restore your computer to a previous date when it worked properly.
Jan 10, 2010 | Dell Inspiron 1525 Laptop Jet Black
Dead Dell Latitude D420 laptop--virus?
if u had a virus infection pobably some file on system32 has ben deleted so windows cant start up just show's the loading bar and thets it
If u have the Windows Cd
Boot from Cd
Repair the Windows
iff u dont
formate it
Jan 05, 2010 | Dell Latitude D420 Notebook
Toshiba a105 screen goes black then stops booting up when startng
try access the safe mode.. then remove the some virus or.. if you installed same latest program remove it then start again...
it you dont installed any program check the control pannel,, add and remove program remove all programe not neccesary...
Jun 08, 2009 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
19 people viewed this question
Alun Cox
David Payne
David Payne
