Monitor buttons don't function while monitor is connected to a PC (Power, OSD, etc.). Buttons function normally if the monitor is disconnected from the PC.
  • edwaslo Dec 06, 2008
    Turns out that the board on the Monitor that receives signals from the PC was fried so the front panel became disabled as soon as you connected the video cable to a PC.
    Luckily it was still under warranty and was fixed for the price of postage.
    President:
  • 2,110 Answers
First boot ur system then u can only access to the buttons..
Posted on Nov 30, 2008
How do I unlock the OSD?
Unlocking the OSD menu
  1. Turn the monitor off.
  2. Press and hold the Menu button.
  3. Press and release the Power button.
  4. Release the Menu button.The OSD is now unlocked.
Apr 26, 2012 | LG Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
OSD LOCK
Normally the OSD lock will only be displayed for 5 seconds.
Regardless you should be able to get rid of it by pressing holding the up arrow key for 10 seconds.
If this fails to resolve the issue try this. Disconnect power cord. Now press and hold button 1. Plug the power cord back in. You may have to press the power button while still holding button 1. The OSD lock should clear after that.
Hope this helps.
Oct 02, 2009 | ViewSonic E70f 17" CRT Monitor
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Jan 27, 2009 | Acer X193W LCD Monitor
On the side of the monitor are 6 little buttons. What is the function of each of these buttons.
I found a user guide for a CMV938A that I expect the buttons to be the same.
Here is a link to the manual: CMV938A User Guide
The buttons are described on page 6 of the manual.
1.
Power On/Off button and indicator LED.
Green: Normal.
Orange: Power Saving.
Off: Power Off.
2.
Enter and exit the OSD menu.
3. O/>
•* Quick brightness adjustment and increase contrast/brightness.
•* Move selection right when OSD is displayed.
4. O/<
•* Quick contrast adjustment and decrease contrast/brightness.
•* Move selection left when OSD is displayed.
5 Auto/▼
• *Automatically optimize positions, phase, and clock when OSD is not displayed.
• *Move selection down when OSD is displayed.
6 Turbo/▲ •
*Switch between picture, text and economy modes.
• *Move selection up when OSD is displayed.
Nov 05, 2008 | Computers & Internet
Relisys TL766 monitor. OSD menu continually open, wont close. Standby button doesnt always function.
Here is a definite solution to all those having problems with OCS menu on Relisys TL 766 Monitor.
Having tried many of the posted solutions none of which worked. The only option was to visit my local PC repair shop who disconnected the OCD monitor for UK £15.00. Spare parts for this model are no longer available. Only down side was the power indicator light in middle of now redundant control buttons does not work. Otherwise a monitor works perfectly. NO MORE STRESS.
Oct 15, 2008 | Relisys TL 766 Monitor
Osd main controls locked
that depends on the brand and model of monitor ,
it normally takes 2 buttons pushed at same time to unlock it.
if you have side buttons its normally them.
May 12, 2008 | Gateway FPD2275W LCD Monitor
OSD Lock
  • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Apr 18, 2008 | AOC LM729 17" LCD Monitor
OSD Menu won't turn off
Known issue -- can get a replacement if still under warranty. The planar rma techs are really really nice.
May 13, 2007 | Planar PE170 White (Black, White) 17 in....
Computers & Internet Logo
David Payne
David Payne
