Question about Toshiba Satellite A135-S2386 Notebook
Remove keyboard need to remove keyboard properly
  • 34 Answers
Hello
That cover on top of speakers right on top of keyboard it is also covering the hinges please take it off and then you can remove the keyboard.
Thankyou
Posted on Nov 30, 2008
How do I remove the keys on a Logitech MK700 keyboard to clean properly?
Try using simple flat-head screw driver. It should remove easily, but i don't think that'll solve your problem.You should pry apart your keyboard with screws and use damp cloth to clean the board, as well as rubber buttons. I'm not so certain about that, but you should try it. Dusan
Jul 09, 2014 | Logitech Wireless Access Duo Optical...
Aspire 5734z4958
If your keyboard is not working in your laptop, it could be that your keyboard cable has come loose from your motherboard over time. This is not usually the case, however. In most instances, the keyboard has shorted and a replacement keyboard needs to be installed on the system in order to make it work properly again. If you are not used to working on laptops, I would not suggest you do this yourself. The keyboard is usually anchored in by several screws and in certain models of laptops can be difficult to remove. A computer repair shop should be able to remove the keyboard and get you a replacement. However, if you are careful, you can remove the keyboard yourself. The keyboard should have information on the back of it such as model number. You can use this to find and order a replacement keyboard.
Oct 22, 2013 | Computers & Internet
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Keyboard is not working properly on my 5672 need to push very hard to make them work
hello
if its Acer Aspire 5672, you will have to replace the entire keyboard -- if you are mechanically inclinded, remove the bottom portion of the notebook (many screws involved) remove keyboard, clean out all the dust using air can or compressor-- make sure the connection from mainboard to keyboard is not recessed.
Jan 03, 2012 | Acer Corolla Computers & Internet
How do i replace the keyboard on an acer 4630z?
Disassembling a laptop is not a task for a "novice" technician.
If you need to ask "how", I suggest that you take it to a qualified technician, for proper repair.
Mar 09, 2011 | Computers & Internet
I need to know how to remove the keyboard so i can clean it. i spilled a little beer on it! and some of the keys are not working properly
Turn it off remove the battery get a spray bottle fill it with destilled water turn the keyboard upsidedown over a clean towel spray the keyboard till it drips clean;meaning the drops of water are clean. When finished spraying, Dry with a hair dryer for 30 minuts on low heat let set on clean dry towel for 12 hrs Check for resisual moisture. If any repeat drying proceedure. let set another 12 hrs on clean dry towel
till dry replace battery fire that muther up
way simpler tham removing the keyboard and cleaning it.
best of luck
May 20, 2010 | Computers & Internet
Dell Keyboard install
please tell me your problem properly
what do you want install driver
or remove the driver or any other thing
Apr 07, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
I need to replace the keyboard for a Travelmate 2410. I have the replacement keyboard but am finding it difficult to open the cover. I have removed all the screws from the underside but it is still not...
You need to remove the cover where the power button is located, be careful as there is a ribbon cable attatched to the mainboard under here to pulling to vigorously may cause the cable to get pulled out. Then you need to remove the screw(s) holding the keyboard down,thats all just put the new keyboard abd tight the screws properly.
Be Happy always
regards
Dec 09, 2008 | Acer TravelMate 2300 Notebook
Toshiba Satellite A135-S2386 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
