I want to add a second drive.
How do I remove the HDD holder to add a second drive?
  • 2,110 Answers
Fix a same type of HDD i.e IDE or the first one
Posted on Nov 30, 2008
How to installing second HDD on emachines t3504
You'll get several answers if you Google
"how to install another hard drive in pc"
Apr 26, 2014 | E-Machines T3504 PC Desktop
Can't remove hard drive from veriton m410;
You must slide the HDD holder first
Then remove the HDD
It maybe needed to tilt the HDD a little to remove it.
You can find more info HERE:
Dec 20, 2012 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Cannot see second drive.
I am sure your missing jumper setting.
so you should change hdd jumper setting.
how to change u r hdd jumper just visit this site.
Nov 11, 2012 | Computers & Internet
Add 2nd HDD to Gateway DX4860
May 10, 2017 | Computers & Internet
I want to add a second hard drive to my computer and I need the metal cradle to mount it in.
get an external hdd closure for you to add another hdd slot because as far as i know, only one hdd can be added on the interior
Feb 18, 2010 | HP Pavilion HDX9494NR Notebook PC
Replacing HDD Acer Travelmate 244
First, you must remove the battery by pushing the battery release latch and sliding the battery out from the machine.
The hard drive will be located behind where the battery was, and you should be able to just carefully slide it out. Then you have to remove the hard drive from its holder by removing 2 screws.
Go to pages 52 and 55 on this document for complete instructions.
Mar 14, 2009 | Acer TravelMate 240 Notebook
Need to add hard drive and memory to emachine tower 333
Okay, this is what you do, I don't really think that Win 98 supports dual HDDs, but I think I can help.
If you have a IDE Dual Cable (plug into the Motherboard and have two connectors attached), Do you see the mini plug by the connector on the HDDs? (Usually white or different color) on the Original HDD, put the miniplug to "Master" and the second (added) HDD to "Slave" or you may be able to use the "Select" on both.
What I do recommend though is going ahead and burning all of your precious data to CDs and buying a newer HDD.
Instead of 4 Gigs, get something around 80 Gigs.
If you give me the motherboard specifications, you may be able to update your RAM to 128-256 MB
Mar 09, 2009 | Microsoft Windows 98 Second Edition for PC
Hard disc
Switch off the Printer and remove the Power Cord.
1. Remove 6 T-15 screws (Type B) from
the HDD Access Cover. Remove the
HDD Access Cover.
2. Remove the HDD with its foam holder.
Disconnect the HDD Cable and Power
Supply Cable from the HDD.
When Installing the Hard Disk Drive make sure the holder is
placed in the right position so that it cannot move.
When the Hard Disk Drive is
replaced perform the
following Service Utility: Backup EEROM
Backup EEROM
This Service Utility is used to restore the contents of the EEROM
when a service engineer has replaced the Main PCA or the Hard
Disk Drive. If the Main PCA is replaced the EEROM content,
backed up on the hard disk, is restored to the Main PCA and if the
Hard Disk Drive is replaced the EEROM content is saved to the new
Hard Disk Drive.
Before using this utility, make sure that you are using Firmware
version A.02.xx. If NOT, make sure that you upgrade the
Firmware version to A.02.xx BEFORE using this utility.
1. In the Service Utilities submenu, scroll to "1.6 Backup EEROM"
and press Enter.
2. Select the part that has been replaced and press Enter
3. If you select "Hard Disk Drive (HDD)" a message confirming
selection is displayed. Press Enter to confirm and exit this utility or
press Back to cancel.
4. Press Back to return to the Service Utilities menu.
Sep 23, 2008 | HP Designjet 5500 (42 in.) InkJet Printer
Mobo only one ide connection socket for HDD & CD-Rom
yes you can add both your HDD and CD-ROM Drive with the same IDE, get a IDE data interface cable (BUS) atleast three connection point. Add 1 to mobo, second to HDD and top 1 one to CD-ROM drive. Just connect and dun wrry m sure it will
If any problem just Ask me
Apr 07, 2008 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
