Question about GE Spectra JBP78 Electric Kitchen Range
Hi, my GE glass top oven has a bridge burner that won't work.
Model # JB968S0H1SS
GE, Electric glass top oven.
Bridge burner no longer works. The knob will still turn on the large burner, but the bridge burner will not work.
Any answers or suggestions on how to troubleshoot this problem would be greatly appreciated.
  • 123call Nov 30, 2008
    Thanks for the advice. I will take a look and get back later.
    Sergeant:
    Champion:
  • 338 Answers
The bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Posted on Nov 30, 2008
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
Large section of dual burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jul 07, 2009 | GE 30 in. Profile JP989 Electric Cooktop
I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Apr 07, 2009 | Kitchen Ranges
Front right burner on GE glass top range not working
Feb 28, 2009 | GE Profile JKP18 Electric Single Oven
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
GE Elec Range - front left burner will not turn on
Dec 26, 2008 | GE Profile JB968SHSS Electric Kitchen...
Both 6'' & 9'' burners come on however I turn the 6/9 knob.
may be a problem with the switch itself, but honelstly dont take offense but make sure the knobs are on correct knob stem, it squite common for someone tho clean the knobs and not put them on correct valves
Nov 16, 2008 | GE Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
782 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
