Question about Black & Decker GT300 Coffee Maker
My coffee maker wont work
My coffee maker stopped working when i pushed the 14oz button the creamy button also came on and they both started flashing. the coffee maker will not even begin to brew anymore. it just keeps doing that same thing any time i press a button.
  • frandave Apr 07, 2008
    Mine worked fine about 6 times. This morning, I tried to use it on the 9 oz. setting.  Blue light flashed a few times ; then, both 11 oz. and creamy buttons started to flash but NO coffee. Called Black & Decker and they said they no longer make this model and would be willing to replace with a "personal 2 cup coffee maker" ; not another pod type pot.  Too bad for me.
2 Suggested Answers
SOURCE:
SOURCE: Home Cafe GT300 Black and Decker- won't work, brand new
I have the GT300, and it also started having problems with the 14oz and cream loight s blinking. After trying the unplug and replug thing I gave up, I came back to it the next day and it started working again so I just kept running it over and over until I got it to fail again when I opened the lid and put a pod in to make a cup of coffee. It wouldn't work again so I unplugged it and set it back up and held my hand on the lid and applied a little pressure and it started working again, so far with a little preesure applied it still works. My guess is there is a switch that dosen't make as well as it should, you don't have to hold the lid down during the entire brewing cycle just long enough for it to get started. Good Luck
Posted on Dec 08, 2007
Espresso and Longo buttons flash simultaneously and continuously
Try holding both buttons down while you turn the machine on until they stop flashing - usually about 5 seconds. This will reset the machine to its factory settings. Hope this helps.
Apr 06, 2012 | Nespresso Le Cube
When pressing the "start/stop' button
the pump is not getting water, make sure it does
Nov 11, 2017 | Nuova Simonelli Mac 2000 I Group Espresso...
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
It wont stop beeping
Is it still beeping? ;) It will beep if you have the automatic brewing programed and the grinder and it's lid are not in place.Once you have put the grinder back in place, push the small white button down that is on the grinder lid. The beeping will stop. Don't press the program button again or it will start beeping again...but if you do, just push that white button again.
Aug 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Light flashes remove filter and clean
did try kenmore website
sears has a great place for trouble shooting
Feb 06, 2009 | Kenmore KCM12 Coffee Maker
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
May 07, 2007 | Black & Decker GT300 Coffee Maker
Black & Decker GT300 Coffee Maker Logo
61 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
eyecam
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
