Can't find inserts/holes needed to wall mount the television.
On the back of the set (50" Panasonic Viera model TH-50PE8U - it's a short production model) there are 4 plastic caps that look like they can be popped off and perhaps have holes inside that can be used to mount with, but I can't find any information on the model anywhere. Any help would be appreciated.
  • Anonymous Jan 30, 2009
    thanks this helps
Does this tv have a DVI output?
Posted on Jun 10, 2009
    Problem Solver:
  • 11 Answers
I went thru this with my tv.. you can pop off those caps, if there's no obvious way to remove them
then when you shop for a mounting system, get a bigger/ higher capacity mounting system with generic connector system.
Dont go for the cheapeast price.
Posted on Nov 30, 2008
I have a panasonic viera plasma tv model number TC-P60U50, where on tv do I put brackets to mount to the wall?
You will need to purchase a suitable wall mount separately. (You'll need one for LARGE TVs.) On the back of your TV set you'll see there are 4 holes in the lower-central region of the rear panel. They are about 20" apart (left-right) and about 12" apart (up-down) These should match up with the bracket that comes with your wall mount. You will need M8 metric screws that are about 1.25" long. These will also be included with the wall mount. (Which will include some general directions for wall mounting.)
Here is a manual for your TV:
PANASONIC Viera TC P60U50 Owner Manual Page 7
Feb 09, 2016 | Panasonic Televison & Video
Panasonic TH50PE8U
Panasonic Product Support - TH-50PX80U
shop.panasonic.com > Get Support
PanasonicOwner's Manuals. Owner's Manuals and Documentation. Operating Instructions Manual- TH-50PX80. Warranty. Warranty information. Warranty - TV Plasma ...
Panasonic TH-50PE8U Flat Panel Television User Manual
tv.manualsonline.com > ... > Panasonic Flat Panel Television
... and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline. ... Panasonic TH-50PE8U Flat Panel Television User Manual ...
Oct 29, 2015 | Panasonic Televison & Video
Is th-50pe8u audio out fixed or variable
I do believe those audio outputs are fixed pre amp outputs that connect , for example, to a home theater system.
May 21, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
I need a Panasonic TV TH-42PD25 base stand! I've searched ebay, no luck. This might sound dumb, but can I use base stands from any of the other Panasonic 42" models?
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
Nov 30, 2012 | Televison & Video
I have a Panasonic TH-42PZ80U 42" plasma tv I would now like to mount on a wall. I have gotten conflicting information as to whether it is VESA or not. Can you tell me anything about wall mounts for...
Just purchase a mount for 42" and above They come in different styles for your likening and make sure the wall bracket gets mounted into the wall studs and your all set. No major job. I get $150 all day long for those installs.
Nov 26, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
How do i wall mount this tv
theres 4 fixing mounts at back of tv covered by plastic caps just remove those to mount
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
R-tune button doesn't work. defaults to video mode after turn off
the mounting screws into the tv may be too long and short out a communication cable. remove all mounting hardware and see if it still has this problem.
Dec 02, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Does model th-c42hd18 require only a panasocin wall mount bracket. Seems others do not work
I am not familar with your exact model but my Panasonic TH-42PX600U 42 in. Plasma uses a generic brand wall mount. The first mount I bought would not fit so I returned it and bought a different brand which worked well. Start shopping your local stores (even walmart has a couple of different types to choose from), carefully open the packaging in case you need to return it and see if it will fit the mounting holes on the back of your TV. If it fits on the back of the TV then you should be good to go.
Jan 11, 2009 | Panasonic TH-42PX600U 42 in. Plasma HDTV
Televison & Video Logo
354 people viewed this question
Top Televison & Video Experts
