Question about Toshiba Satellite M30X Notebook
When i was adding a restoration disk to my laptop it went blank
And when i turned it back on a black screen came up saying delete restoration data and proceed to system boot menu but i dont know how
The screen has gone black, I have turned it off and on a couple of times, it just comes back black. How do I get back to the home page?
Did you try resetting the screen?
Not sure what screen went blank, but check the manual for reset and the consequences. Like loosing all data on the device.
Next question, please ad the device name, model and brand in the question. And when the device has a OS, please what OS, including the version. Thanks.
Mar 13, 2015 | Tablets & eReaders
Well i turn it on then it says hard disks file system corrupted an when i click restore it gets to 100 then goes blank comes back on then said restore and ive done it 6 times
Try it in safe mode.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
I recently left my laptop on, but forgot to plug in and the laptop shutdown. On turning the acer aspire 5720 back on it won't start windows vista, the screen remains black. I have tried system repair and...
what i would do is go in safe mode and u do that by when u first start computer puss f8 key back up the data and sad to say reinstall will be needed if u cant get the data out that way u will have to 1 take that hard drive out and conect it to anther computer or take it to a computer shop and have then take the data off.
our hard drive maybe going out but could just be bad sectors and with a full restore that will fix it
Aug 31, 2010 | Acer Aspire 5720 6497 Laptop
Philips freevents laptop will turn on but show a black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back. If that doesn't work get back to me...
Feb 22, 2010 | Computers & Internet
My ps3 freezes in the main menu Yea i have the same problem... when i turned on my ps3 and was gonna log into my psn it just freez up.. so now i'm stuck at the  "Log in Naddepusen" (psn) with the wave...
**USE A FLASHDRIVE FIRST TO BACK UP YOUR SAVED GAMES**
Settings > System Settings > Restore PS3™ System
Delete all hard disk content and restore the system software to its default settings. Follow the on-screen instructions to perform this operation.
After the operation has been completed, the initial setup screen will be displayed. Follow the on-screen instructions to complete the operation.
Notices
  • When you perform this operation, all data on the hard disk will be deleted. Also, the system software will be restored to its default settings. Be careful not to accidentally delete important data as the changes cannot be undone. Data loss or corruption is the responsibility of the user.
  • Do not turn off the PS3™ system during this operation. If the operation is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • During this operation, the power button on the system front and the PS button on the wireless controller are not active.
  • You cannot use this feature to go back to an earlier version of the system software.
  • You can shorten the formatting time by selecting [Quick Format] from the hard disk format methods. However, in this case it may be possible for some deleted data to be restored if a specialized tool is used. Select [Full Format] when formatting a hard disk that contains important or sensitive data.
May 29, 2009 | Sony Playstation 3 (PS3) Console
E recovery not recognising a blank disk
First try doing a restore to an early date. I believe that  the softwware for rwadig the CD may be damaged also.
Jan 24, 2009 | Acer Aspire 5004WLMi Notebook
Error message
What was your coworker doing on it? I would say you need to at least do a disk check. You can do this through windows repair console or in Vista you can boot to the disk and have it check boot up problems. Very easy.
Dec 05, 2008 | Compaq Presario Notebook
Operating system not found
This message means that the hard disk was not detected, this is due to either the BIOS setting was changed or the hard disk has failed.
Try booting up with a DOS disk and run FDISK, and see if it detects the hard drive, if possible run a diag test program.
Nov 22, 2008 | Compaq Presario 700 470024-192 Notebook
Blank/black screen
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
5
Oct 12, 2008 | Toshiba Satellite A55-S106 Notebook
I have a Toshiba Satellite A105
1. Please press and hold on F8 key immediately after power on then select Safe Mode. If you are able to go to the desktop, please go to Start-All Programs-Accessories-System Tools-System Restore. Please select a date when your laptop was working properly. This will the software changes beyond that date but will not delete your personal data. Your laptop will restart and give the message that the restoration was completed. Please connect the ac adapter so that the process will not be interrupted. If this does not work like if you are not able to
2.Do the system recovery but with this option, you will lose everything and your computer will be restored to the out of the box state. For you to do this, you will need to use the recovery disk that came with your laptop. Please load the disk 1 then turn your laptop off. Please press on the power button to turn it back on then immediately press and hold on the F12 key. Select CD/DVD from the boot options. Windows will be loading files then select Recovery Wizard. Select the Default Software after that then select the Recover to the Out of the Box State. After the first disk, you will be prompted to load the second disk. Please connect the ac adapter since the entire process will take around an hour.
Hope this works. Thank you.
Sep 22, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite M30X Notebook Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
