Question about Kenmore 15864/15862 Top Load Washer
My washer machine is making a knocking sound
When the washer is in spin cycle, it makes a loud knocking sound like its going to start hopping across the floor. I turn it off then turn it back on and it still does it. Need help asap.
  • Shivd Mar 01, 2009
    i have the same problem but do you know the name of the rubber part?
  • Anonymous Mar 16, 2014
    it is a wooden floor and been told needs strengthening because the machines are now lighter?? as more plastic in them?
Therer is a ribber gromet at the bottom of the drum , this gromet wears out , we had ours replaced with anewer version and is fine now
Posted on Jan 21, 2007
Try balancing the clothes evenly,if that not the problem,the balancing ring at the very top is either broken or a snap ring or rings are off.
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Why is my washer making loud knocking sounds?
the bearings may need to be changed
Aug 18, 2014 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Washer makes loud noise at start of each spin cycle
sounds like ur o erloaded. but did u run a diagnostic test??
Jul 08, 2014 | Maytag MAH2400A Front Load Washer
Washing machine makes a loud whining noise when in high speed spin that it has not made before. Noise seems to come from the soap inlet tube.
usually when a front load washer starts making noise in the spin cycle it's not good,most of the time it's from the owner using to much detergent,it eats the spider gear and then it's time for a new washer,the gear costs around 500 bucks,next it will start to bang around and get real loud,i've seen the rubber boot get ripped off because it bangs all around,if you're using alot of detergent most likely this is the start of your problem,when you read the back of the bottle the measurements are for a top load washer not a front load so you better check that,also you could have a broken shock,also you can pull the middle of the pump out and check to see if there are any filings in there,i've seen that before.put it on high spin and listen to it,if it sounds like a knocking sound don't waste your money and call someone in,change out the washer and watch the cd that comes with it and use less detergent,i hope this isn't your problem but when the noise comes from the spin cycle it's usually the spider gear.
Aug 26, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Washing machine knocks in cycle
if its a whirlpool top loading washer, sounds like a bad motor coupling.( the machines equivilent to a belt.)
Oct 25, 2008 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
957 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
