Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Missing curved trap tube at bottom of vac
Do not know the name of this part to reorder
    Problem Solver:
  • 7 Answers
It is called a u tube
Posted on Dec 04, 2008
Eureka mighty mite
THE INTAKE TUBE IS BLOCK PLUGGED...! FROM BOTTOM OF VAC SCREWS REMOVE WHERE TUBE IS AND CLEAR OUT BLOCKAGE REVERSE PROCEDURE FOR RUN.
Jun 14, 2013 | Vacuums
I followed the trouble shooting advice for a Hoover steam vac that has non-spinning brushes. Turbine ordered and replaced. Female receptacle still is not spinning. What now?
There could be several reasons for this. Remember that the brushes will not turn unless the dirty water tank is in place. Also the handle must be released and tipped back. It is also possible that the rubber seal that the lower tank sits on is missing. If you look down into the motor area, there should be a large, round rubber seal that the lower tank sits on. Look for the round tube that protrudes from the bottom of the dirty water tank. This tube sits against the seal. If it is missing it will need replacement.
Jul 11, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My vacum will not pick up, it is spitting the dirt out?
Check for blockage.
Most likely place is in the tube leading up from behind the beater bar. While unplugged, remove beater bar & belt & check.
If you have a strong shop vac, remove beater bar, belt, and bag, applying suction to the tube in back of the beater bar will many times dislodge the clog with little effort, sometimes though it will take some fishing around with a stiff piece of coathanger wire or similar.
Normally when you can apply suction with the shop vac to the tube in back of the beater bar & feel suction at the tube were the bag connects, you know you've got it all and you should be unclogged. Put it back together and you should be ready to roll.
Feb 11, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Vacuum squeals when running. Big boss smart vac 4870
most likely you have something trap in the blower fan. if not chech for some obtruction in the tube. a piece of paper or the like. also check you belt.
Feb 06, 2011 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Kirby Heritage 84. Great condition except the part that connects the innerbag is missing. I don't even know what it is called. I can open the vacuum cleaner bottom and see that the part is...
The Heritage 84 had two different bag assemblies available. One is a dump-out bag. The dirt simply dumps through the bottom. The other is the bagged style which has a full length zipper to open it. Inside it should contain a "bag fill tube", and a top adapter to attach the bag onto. The oval fill tube is no longer available, but a round tube can be installed with a bit of efort.
Dec 12, 2010 | Kirby Heritage II Vacuum
No suction on floor part
From your problem description, you may have a blockage in the foot. Check the intake under the vac by the roller.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
May 01, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Model Fantom Thunder (quite old) still runs,no suction from wand, very poor from bottom
sounds like you have something stuck in the air way you can flip the vac over and they had trap door you open to clean it you may have to use coat hanger straigten out with a small hook on the end
Feb 22, 2010 | Vacuums
My stem vac won't **** up the water.
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Sep 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
27 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
