Question about Hampton Bay 24750 Huntington III Ceiling Fan
Wiring in a new speed switch
My niece had pulled out the power off/3 speed chain cord out of the fixture. Before I could see the wiring they had taken it apart. I bought a new switch. Inside there is a orange wire on one side, purple, gray and yellow on the opposite side of some sort of switching assembly. The grey is already attached. I have one black power wire. The new switch has one black, one red and one blue wire. Is there a wiring diagram I could get to properly put in the new switch?
  • pabloamador1 Dec 11, 2008
    I have the same problem, but i found out that the black wire went on the L side and the other colors, I have no idea can some one help me. Wire colors that are left red, purple, yellow,grey.
  • 833 Answers
Not likely.  This is a procedure...not a solution.  First, check the switch out with an ohm meter.  Four pulls will put the switch in off/1,2  and 3.  Find the one that conducts through on all the speeds except off.  You'll hook that to the black.  Note which one is first, second and third in order.   You'll need to know that.  Take the black power wire and hook it to any of the fan wires...other than the white.  Note the speed you get.  Do the others.  Now, connect the switch wires appropriately to re-establish your speeds.  Tape connections before each trial to minimize hazards.
Posted on Dec 12, 2008
Fan is stuck on high, and I'm trying to install a 3-speed pull chain.
Do you know the make/model of fan? Hopefully you have the correct switch.
Mar 27, 2016 | Dryers
My ceiling fan has two pull chains The pull chain for the light broke too short. When it broke the light was off. Now I don't have a ceiling light for my kitchen. How can I replace the pull cord?
You will need to replace the pull cord switch. It is inexpensive. You will need to open up the fixture and reemove the old one. Usually it is held on with a nut. If you are not sure of what switch to buy, take out the old one and bring it to a hardware store. Make sure the power is off. Cut the two line to the old switch and splice in the new switch with wire nuts, also use some electrical tape to insulate the connection. Reinstall the nut and close up the fixture. Good luck.
Oct 05, 2011 | Hampton Bay 52 In. White Redington...
I have a harbor breeze cieling fan with a 3 speed pull switch. It has 4 wires black /gray /brown and purple. The switch has L/1/2/3. I need to know which wire goes in which position ?
Old switch and new switch have to be compared using multi-meter or continuity tester.
Each 3-speed switch has identical pull-chain sequence: off-high-medium-low.
Each 3-speed switch has only one wire that connects to Hot wire.
But the other three wires can vary.
For example connect power to switch Hot wire. Let's say switch is in off position. Pull chain once for high speed and power might flow to just one wire, or it might flow to two wires, depending on the switch.
Pull chain again for medium speed, and power might flow to just one wire, or it might flow to two different wires.
Pull chain again for low speed, and power usually flows to just one wire.
Easiest place to start is to find which wire is Hot.
Only one wire connects to Hot power.
That same wire on the new 3-speed switch will connect to all other wires. When testing, only one wire connects to all other wires.
Once hot wire is determined.
Then test which sequence of wires receives power each time chain is pulled.
Repeat same test on old switch.
Note how old switch was connected. And then map the change-over to new switch.
Open following link for resources:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 01, 2011 | Electrical Supplies
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
Need a replacement, where do I get one?
If I understand correctly you have a 3-speed fan.
And you need a 3-speed replacement pull-chain-type switch
Lowes carries 3 speed fan switches in the light fixture department.
These switches have multiple wires.
At any given time, there is one-and-only-one wire that connects to power from wall switch.
Lets call this the Power wire.
As you pull the chain, the power passes through the switch and goes to one-and-only-one of the other wires.
The other wires connect to windings in the motor.
The different motor windings control fan speed.
The key to replacing the switch is recording where each wire went before you disconnect old switch.
Once you know which of these wires is the Power wire, then you can test other wires with a continuity tester.
You also know the pull-chain sequence is OFF - HIGH - Medium - Low
Mark wires in fan and mark wires on old switch.
Pull out old switch.
Use regular electrical tester to find which wire in the fan is the power wire (separate wires, turn on power and test each wire to metal part of fan)
Now test the switch wires.
The switch is out of the fan.
You marked the wires so you know which wire is power wire.
Put the continuity tester on the power wire.
Test power wire to each of the other wires.
Click the switch and test to each of the other wires. Mark which wire lights up continuity tester.
Click the switch and test again. Mark which wire lights up continuity tester.
Click again, until each wire is marked in the sequence.
When you click the switch and no wire lights up, then that is the Switch OFF position.
Do the same test on the new pull-chain switch.
Connect the wires to match your testing.
Oct 25, 2010 | Westinghouse Electric Westinghouse...
In replacing a broken pull chain (no 3-way power here: simple pull-on/pull-off) on the 3-bulb light fixture of my fan/light combo ceiling appliance, I lost track of how to re-attach the two black wires...
I assume the switch operates the lights only. Besides the ground (green or bare) and the neutrals (4 white wires all connected together), the only wires of interest should be 4 wires (black) from the fixture and the 2 wires on your switch. Of the 4 black wires, one of them is the hot wire and the other 3 connect to the three bulbs. Connect the hot wire to either one of your switch leads and connect the other 3 wires to the other switch lead.
If you don't know which of the 4 black wires is hot you can find it by the process of elimination as follows---- connect any three of the black wires together (then supply power), if nothing lights, then the 4th wire is hot. Otherwise 2 bulbs should light. Remove one wire from this trio. If nothing lights, the wire you just removed is the hot wire. Otherwise, one bulb should light and one of these two remaining wires is the hot wire. Take one of those last two wires and connect it to one of the other bulbs. If it lights, then the wire you just moved is hot. Otherwise the one you left behind is hot. I hope this is helpful. Good luck. Be safe! Al K
Aug 03, 2010 | Westinghouse Electric Ceiling Fan 3-way...
How to attach an on/off chain to a ceiling light- the original broke off somewhere inside. The fan switch is intact. This is one unit.
You need the little coupler thing that connects to the ball that makes up the chain. If you dont have the coupler ... you could get one at your local Ace Hardware store ... or you could just purchase a similar switch which would have the coupler on the chain.
Jun 07, 2010 | Leviton 1689-050 Pull Chain Fixture Switch
Chain to light does not work
Most paddle fans that come with a light kit (or provisions to add one via plug / jack later) provide at least 3 wires (most times 4 though) that will need to be connected to the house wiring. Those wires are:
1) Green, or Green with a Yellow stripe - this is the grounding wire and is connected to the grounded metal junction box or other ground wires.
2)White - this is the neutral wire and is connected to both the fan motor and light fixture.
3)Black - this wire connects to the fan motor. This wire along with the white wire completes a circuit for the fan.
4)Blue - this wire connects to the light fixture. This wire along with the white wire complete a circuit for the light fixture.
Ideally, the junction box in the ceiling has a neutral, ground and both an unswitched power source *and* a switched power source. An unswitched source is always on (regardless of any switch's position) while the switched source is controlled by one or more switch(es) near a door(s). Use a meter or tester to determine which wires are switched (probably black or red) and unswitched (probably black but may be red, too). Label them or orient them in such a way that you'll remember which is which. Turn the power off.
Connect the paddle fan's blue wire to the switched wire, the black wire to the unswitched wire(s), the white wire to the other neutral (most likely white wire(s) and finally, the ground wire to the rest of the ground wire(s). Turn power back on.
Wiring in this way allows the light fixture to be controlled by the wall switch(es) and the fan by the pull chain on the fixture. Turn the wall switch on and pull the chain until the light turns on. You can remove the long chain once the switch turns the light on and off so it is not accidentally shut off at the paddle fan later. Change the fan speed from high to low and eventually off with the chain.
If you only have a switched or unswitched power source in the ceiling, you'll have to connect both the black and blue paddle fan wires to whichever type power you have in the ceiling (switched or unswitched). If you're using a switched sourced, that switch will have to be left on in order for the fan or light to work.
If you have wired in any of these methods already, it could be that the switch for the fixture has failed, and should be replaced with a like-type switch.
I hope this helps!
May 20, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Trying to install - don't know which wire is the "line", which is load "A", etc.
Hi there, Without getting technical, I'm going to assume you have two wire's coming out of your fixture - which you've already identified as the line (aka. power/hot leg), and load (switch leg). And, you want to know which side of the switch to splice (connect/hook) these wires to? Well, on a switch, it doesn't matter. You should have two wires coming from your pull chain switch, right? If so, then connect one wire (fixture) to one wire (switch)  - and the other wire (fixture) to the other wire (switch). And you should be good to go. Now remember, before you begin to work on this fixture, to please turn OFF the power going to the fixture. I always do as licensed electrician, and I always make this part of my practice when helping others, that they do the same. Thanks! As I said from the beginning..."Without getting technical"; I'm double checking with you that you are absolutely sure that you have, and know - the wires coming from the fixture - are for sure, the line and load wire's. Because if not, then please contact me with the information you do have - and then I'll help walk you through with it. I hope this helps, and works for you. Good Luck! - JR
May 09, 2010 | Gardner Bender Gsw-34 3 Speed Pull Chain...
Cannot turn off a pull-chain fixture
It sounds like you have accidentally by-passed the switch. The switch only needs one power leg to the pull-chain switch and the other 3 wires go on the other wire of the switch. The white wires get connected together as you have done.
Please turn off the power before you make a change.
Sep 19, 2009 | Kitchen Appliances - Others
Hampton Bay 24750 Huntington III Ceiling Fan Logo
562 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
