Question about Kenmore 73952 Gas Dryer
Gas dryer will not ignite - Kenmore 73952 Gas Dryer
  • Anonymous Dec 24, 2008
    gas dryer will run but no heat is produced .
    Gas is not igniting
  • 111 Answers
If lint screen on top long// move dial towards 20 , minutes-to off if no click is heard repl/ thermal fuse in back small white fuse 2 red wires/or blue ,, lint screen inside dryer remove bottom panel ,lint screen 2 screws hold black housing once removed mthernal fuse on top white kind of oblong in shape,, let me know
Posted on Nov 30, 2008
No heat
Hello there:
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Sep 26, 2010 | Roper RGK2951W Gas Commercial Dryer
I have a Maytag LDG 4000 gas dryer with electronic ignition. The igniter glows, but does not ignite the gas. I can not smell any gas, so I'm assuming a valve of some sort, internal to the dryer, is not...
Igniter glows - No gas ignition. If the igniter heats
up but the main burner flame is not ignited, remove
power and using an ohmmeter, check the following:
• Open secondary coil
• Open holding coil
• Open wire harness
• Stuck flame sensor (Stuck closed)
Most likely bad gas valve coils.
Sep 07, 2010 | Maytag MDG4000 Dryer
GE Dryer model DWSR405GB0WW Gas dryer will not heat up when auto dry cycles are used (thatt use automatic sensors, such as the permanent press dry cycle or the "auto dry" cycle). Only works in manual timed...
Hello there
when a gas dryer will not heat up properly there can be several different reasons i will try to explain them here for you ok
No heat If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Mar 29, 2010 | Dryers
Gas will not ignite
Dec 31, 2009 | Kenmore 74112 Gas Dryer
Gas dryer ignites at start up then cycles off, won't re-ignite
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedures for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
The link below shows an image of the gas valve coils, which is the most common failure component in the system.
1. Gas Valve Coils:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG3000AWW-%3d%3di3479&PartID=3479
Below are some tips to follow if the coils are not faulty.
Igniter
Gas valve coils
Thermal fuse
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Aug 28, 2009 | Maytag Dryers
The dryer runs, but there is no heat. Gas is
Igniter
Gas valve coils
Thermal fuse
Aug 20, 2009 | Kenmore 700 6972 Dryer
I have a gas dryer , dryer only runs on air. There is no heat. What is causing the problem? Please advise!
Igniter
Gas valve coils
Thermal fuse
Aug 03, 2009 | Dryers
Dryer does not heat-does not ignite
Igniter
Gas valve coils
Thermal fuse
Aug 02, 2009 | Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool Gas Dryer
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type igniter that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before. Is the dryer working at all? If not, here's a way you can narrow down the possibilities of problems:
You need to gain access to view the inside of the dryer, first. With the dryer plugged in, push the start button. If you hear a "click" and the igniter still does not come on, you probably have a bad igniter. If you don't hear a "click", the radiant heat senor is probably bad causing the igniter not to glow. You have to listen very carefully for the clicking noise, though. It's not very distinct with some dryers. Now, the igniter can glow sometimes and still be bad. The way your dryer works; it looks for a certain current potential (roughly 2.7 to 3.2 amps depending on type of igniter) on the igniter before the gas valve opens to ignite. If the igniter is weak, the gas valve may not open. This is a safety feature that prevents gas from leaking into your home. I hope this may help you. Let me know if I can assist further.
Nov 12, 2007 | Whirlpool LGR3624JQ Gas Dryer
Kenmore 73952 Gas Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
