Question about GPX MW3836 MP3 Player
My mp3 took songs off instead of adding.
I have a gpx mw238b 1 gb mp3 ,and i tried downloading songs on to it. it usually lets me and on windows it said it had downloaded the songs. when i took it off the usb cable it had taken songs off. i realize i must have not had it on usb mode but now as i turn it on usb and try downloading the songs again it says i dont have any more room so the music must be on there.how do i find it?
    Problem Solver:
  • 12 Answers
Hello, I probably can help.
If its *full* its do to Filesystem Partially Corruption.
*BACKUP* all your songs. Then right click the usb device, format, than format in FAT format NOT FAT32 or NOT NTFS! THESE WILL RENDER YOUR DEVICE USELESS! Reload your songs and they should be good-to-go. If not i suggest contacting GPX
www.gpx.com
Posted on Nov 30, 2008
After I downloaded songs onto my mp3, when i turn it on it says "GPX" and wont let me do anything else. It wont even turn off. what do i do?
db:: 4.22::why wont my songs play on my mp3 player ax
www.hivmr.com/db/axxs1akj89ss7zs8zmf11d9kmzzj33fa
I download my music, extract the .rar files then take the new folder that has the.mp3s and ... Is there anything i can do to convert the songs to play with the MP3 player? .... LIST ONTO A CD AS AN MP3, BUT I TUNES WONT LET ME AND SAYS ALLSONGS ..... DB:3.37:Nomad Muvu Cannot Format And Mp3 Wont Turn On 37.
db:: 4.31::mp3 player wont play f7 - Hivmr
www.hivmr.com/db/spxap11fkpmm9jss18kz9skc8c8mj977
I have an mp3 player which is usually good but for some reason wont let me ... Howdo I download Itune songs in a format that will play on my mp3 player? ... on Windows 8 after it has been copied to your new computer, or the MP3 can't play the music. .... my stereo will play the songs from Itunes if i burn them onto a CD-R..
MP3 write protect removal - Forums - CNET
Dec 28, 2015 | GPX Audio Players & Recorders
How do you delete all the songs on my GPX MW238B so i can instal new songs in it? i need step by step instructions if you could please.
I'm glad to provide the instructions to delete songs from the Walkman Player. Unfortunately, the player doesn't have the option to delete songs in itself. It is required to connect the player to the Computer to delete the files.
Please follow the steps to delete the files from the Player:
  • Connect the Player to the Computer using supplied USB cable.
  • Close if the Windows Media Player is automatically popping up when you connect the player.
  • Open My Computer from desktop and check if you're able to view the player as a removable drive under My Computer.
  • Double Click to Open it.
  • You can locate the music files under the folders in the removable drive.
  • Select the unwanted files and then press the delete button on the keyboard.
Now, you can transfer the required songs to the Player.
Please let me know if you require any clarifications.
Mar 27, 2011 | GPX MW-238B MP3 Player
Get songs off device
try using another program.
May 30, 2009 | GPX ML648B MP3 Player
READ MY DETAILS AND PLEASE HELP ME OUT!!!!
first of all you cant do a quick format you have to open the gpx file and manually delete and make sure your battery is out of the player then open gpx file and youre music file hold down the the mouse button on the song you want and drag it to the gpx file and the release its called drop and drag will not sync up with media players on youre computer will cause a error songs vary in size so wont always get the 200 hundred song that the manufacturer says you can thats based on 3mb per song
Apr 11, 2009 | GPX MW3836 MP3 Player
GPX MW238B
your internal battery is shot
Feb 01, 2009 | Audio Players & Recorders
My grandson got a GPX ML648b mp3 player for Christmas. On Christmas day we tried to download songs. After 24 songs it would not loan any more. So I deleted the songs and tried again. It would only download...
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
Dec 30, 2008 | GPX ML648B MP3 Player
Gpx mw238b mp3 player can't load music
This player is not Mac-compatible, even though it may see an internal drive of some sort.
Dec 27, 2008 | GPX MW-238B MP3 Player
GPX MW238B Device set up!
I'm not sure that this will help but it seems to address some of your problems. Check out this website.
http://www.gpx.com/store/p/259-MW238B.aspx
Oct 25, 2008 | GPX MW-238B MP3 Player
GPX MW3837 Malfunction
Let it recharge for a few hours - when an mp3 player won't turn off, use the reset button instead of letting the power drain down. Actually, i take it back - this is the worst most godawful manual I have ever seen - this is the first Mp3 player I have ever seen without a reset button.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 18, 2008 | GPX MW3837 MP3 Player
GPX MP3 player
when it is utp hold the select button untill it goes to usb than press hold and it should work
Nov 01, 2007 | GPX MW3836 MP3 Player
GPX MW3836 MP3 Player Logo
71 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
