Question about Garden
How to correctly set knotter on a massey ferguson model 503 baler
Knotter does not release the knot when tripped
3 Suggested Answers
  • 86 Answers
SOURCE: Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
Posted on May 12, 2009
  • 10865 Answers
SOURCE: hay baler twine double knot
Your timing belt has slipped. If you have the repair manual for your baler, this is a relatively easy repair.
Posted on Jun 18, 2009
New holland 317 baler. I have intermittent fault with the knotter. Every 50 or so bales the knot comes undone on one side
try posting this question here and see if they guys can help you. you have to register before you can post a question.
here is a youtube that show some knot information good luck one may help you. try the youtube first.
https://www.youtube.com/watch?v=ZoB_1meRa9A&ab_channel=NewHollandNorthAmerica
https://talk.newagtalk.com/forums/thread-view.asp?tid=59305&DisplayType=flat&setCookie=1
Dec 11, 2017 | Miscellaneous
How do l adjust the cast iron needle lift arm so knotters will knot?
Your taking about a baler right. Adjust the arm so that it comes up and rubs on ,but not tight enough to wear out the knotter claw it also has to come up far enough so the twine can be grabbed by the claw
Oct 17, 2015 | Garden
My needle arm is stuck in the down position, won't raise manually. Newbie
Not knowing the brand and model of your machine makes diagnosis difficult. In most machines that have the bobbin case inserted from the front, you can try releasing the bobbin case and removing it. When my machine jams, removing the bobbin case releases all those threads that are twisted and knotted inside that are "holding the needle captive."
Oct 03, 2015 | White Sewing 1418 Mechanical Sewing...
How to tie a rope around a large tree
Trucker's knot. I use this because it provides great tension and offers a quick release. It's great for mainlining a tarp or even a clothes line.
Oct 26, 2013 | Camping, Backpacking & Hiking
How to thread pull cord on my Talon rotary mower
remove THE COVER THAT HOUSE THE PULL CORD pully. TURN THE WHEEL IN THE direction THAT IT GOES WHEN cord is pulled ( THIS TIGHTENS THE RETURN SPRING) hold this wheel tight..every turm it could spin back rapidly. turn wheel 6 complete turns. align the hole in the housing with the cord hole in the pully wheel. thread cord through both tie a double knot . slowly release now install cover. try it if too loose pull out to max , hold pully, remove knot , cord and turn 2 or 3 more turns, replace cord, double knots , slowly release. replace cover, crank it and cut that grass.
Dec 04, 2011 | Talon Rotary Lawn Mower
The only information written on my hay baler is Mobilco Super 59. I have been trying to bale my hay but the knots on the left side aren't tying. I adjusted this and it tied a few then the knotter on...
The mobilco sounds like a gar lubricant. I bale myself and work on my own machinery. The first thing you need is the make, model and serial numbers. There shuold be a tag somewhere fastened to the machine. Both of mine have the tag riveted to the flywheel side of the frame.Mine are old john deere balers. Balers can be very complicated machines and you need the manual to dial them in right unless you know that machine like the back of your hand. Sometimes you can have tying problems from bad twine that might have been damp or knotters rusty and not moving right. Some times penetrating oil on the moving parts of a knotter will do wonders. I am assuming that you are talking about an old square baler since I dont know what you have for sure. I started having problems with mine when the twine started wearing a pretty deep groove in one of the parts it dragged across (dont remember which part it was) but anyway, I replaced and reshimmed accordingly, and it ties really good now. Hope I could be of some help.
Sep 02, 2011 | Garden
Broken starter cord on briggs and stratton quantum 40 roughly 1994 how to repair
Remove the recoil. Sometimes depending up on model this required complete air shroud removal. Remove the parts of the old rope. Remove the rope fro the rope handle. NOTE the knot in the handle. Brun both ends of the nylon rope with a match and pinch the burned end into as small of circumference as possible. Install new rope into the starter handle and tie the knot. Pull the new rope into the handle until it seats securely.
Prewind the recoil pulley as far as you can easily wind it. Back it off (unwind) just until the rope guide and pulley knot hole are aligned. Then either c-clamp it in place with the rope knot hole aligned with the rope guide hole or have a 2nd person hold it the pretensioned spring and pulley in position. Thread the rope through the rope guide and on into the pulley knot hole. (takes some effort to get it aligned and through the knot hole!) Pull the new rope through the knot hole and tie 1 knot. Pull starter rope and fit knot into pulley knot hole. Release pulley C-clamp or have helper let go of pulley. Rope should rewind into the recoil.
Reinstall recoil / air shroud. Happy mowing!
Thanks for choosing FixYa.
Kelly
Nov 20, 2010 | Briggs & Stratton Garden
HIGH RESISTNCE WHEN STARTING.
If the machine doesn't have a compression release, you need to tie a better knot at the handle (melt the end of the cord with a match or lighter so that if forms a small lump, then retie the knot). I have a new model 435 Husky that does the same thing (no compression release). Good luck!
May 23, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hay baler twine double knot
Jun 18, 2009 | Garden
Garden Logo
602 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
