Back to:
Tags:
Sharp LL T17A4-B  17 in. Flat Panel LCD Monitor
Problem with the monitor
posted by LORD62 on Jan 21, 2007
I have red green rectangles spread across the monitor, I tried formatting my pc, I also tried restoring default factory settings, can anyone tell if my monitor is damaged or if it's my Pc ?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 22, 2007
FixYa! (100)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2983 votes
Have you tried another monitor on the PC?
If the cable and connector pins are okay, I would suspect a problemn with the video / signal board inside the monitor.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problem with the monitor:
I don't want to Accept this solution
Solution #2
posted on Feb 25, 2007
Not Rated (0)
inayat
Rank:Apprentice Apprentice
Rating: 95%, 3 votes
Dear Sir/madam
I have a seventeen Dell LCD monitor, when i start my computer the logo comes on screen and then immediately disappears the same when i press the on adn off button of the monitor it shows the display for few seconds and then immediately the screen gets black.
please solve my this problem.
with regards
inayat
Thank You!
Solution #3
posted on Mar 07, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
try to check the user
Thank You!
Solution #4
posted on Mar 04, 2007
Not Rated (0)
sameerfarid
Rating: 0%, 0 votes
use the degause function in ur monitor,
or check degausing coil,and connected p.t.c.and
related circuit
Thank You!
Solution #5
posted on Feb 01, 2007
Not Rated (0)
rcsubong
Rank:Master Master
Rating: 80%, 23 votes
If your computer is still under warranty, go to authorized service providers so they could replace video cards w/o charge.
Otherwise, go to service centers so they could look at video card. It may be damaged and should be replaced.
Thank You!
Can you Help with these Monitors problems?
Sharp LL T17A4-B (Black) 17 in. Flat Panel...
Hi, I have this Sharp LL T17A4-B Monitor arranged as a...
text is blotchy and screen is sqeezed in hoizontally. PC...
my monitor is staying on green lights but not goning on...
Initial problem was the top backlight generator board one...
after changing the backlight generator board the set...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
