Question about Panasonic Televison & Video
The word STRAIGHT is permanently on my televison screen.
It is located on the bottom portion of the screen and I can't get it to go away. I have direct tv and everything is connected with a Yamaha RX-V1600 tuner
  • 146 Answers
Un-Plug the TV and Plug it back in and if it continues call direct tv it could be caused by their program..
Posted on Nov 30, 2008
  • 435 Answers
Could you please mention your TV model and make?
  • Narmada Anand
    Narmada Anand Nov 30, 2008
    There are two possibilities:
    1) It could be your TV's message like other displays of channel lock.
    Or
    2) It could be because of Direct Tv provider.
    Try unplug the TV for sometime and then plug it back, if this word remains there, then it must be a problem with your Direct Tv.
    Thank you
I have a 46 in lg smart tv and the picture went black ,i still have sound but no picture and every once in awhile the picture trys to light up ?
Could be the back light if flat screen which is located in the back of tv. Try shining a flashlight at the screen at an angle and if you see the picture or a portion of the picture, then your back light is out and you have to figure out why.
Oct 08, 2017 | LG Televison & Video
LG 50" Plasma TV Screen Shrunk!!!
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 29, 2017 | LG 50PC5DC 50 in. Plasma HDTV
How to disassemble an old Hitachi projection TV (model 53sbx59b)
To remove the protection screen and lens from my Hitachi model 53SDX89BA:
1) Remove the speaker cover from the bottom. It is attached by velcro.
2) Remove the 4 screws on 4 plastic tabs on the bottom of the screen frame.
3) Remove the 4 screws on the 4 metal tabs on the bottom beneath the screen frame.
4) Pry the bottom corners loose with a wide blade screw driver and work both sides of the screen frame away from the case from the bottom up. CAUTION: The top does not snap away as the sides do. When the sides are loose let the screen frame hang down vertical and lift the screen frame straight up.
5) The protection screen and the lens will come off together.
When reinstalling the screen frame perform the steps in reverse. Be careful when resnapping the frame back onto the case - there are two small wooden support blocks on the bottom. Don't try to force the frame back on until you are sure the bottom of the frame clears these block. You may find it easier just to remove them temporarily until the frame is reattached.
Apr 13, 2008 | Televison & Video
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Televison & Video Logo
19 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
