Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
How do I remove the top rack on the ge profile built-in dishwashe
I need to remove the top rack of the ge profile built- in dishwasher model 7880 to replace it. I do not know how to disconnect the rack from the bottom spinner.
  • Anonymous Mar 24, 2014
    bottom seal
    Problem Solver:
FOLLOW THE RODS THAAT HOLD THE BASKET AND AT THE END THEIR WILL BE A PLUG! IT WILL COME OFF AND YOU SLIDE THE RACK OUT THE PLUG USUALLY HAS A LITTLE LIP YOU NEED TO EITHER PUSH UN OR OUT TO REMOVE
Posted on Nov 30, 2008
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
HOW TO ADJUST BOTTOM BLADE OF MY GE PROFILE DISHWASER
What do you mean "bottom blade"? Do you mean the lower wash arm? There is no "adjustment" built into the dishwasher, but if it's hitting the heater element (or its supports), you might be able to bend it slightly. If it's hitting the lower rack, make sure your rack has all of its wheels attached, and that it's not bend down.
Sep 25, 2014 | GE 24 in. Profile PDW7800 Built-in...
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
How do you install the end cap #wd12x344
Use a pair of needle nose pliers. Gently bend the end of the rack opening out just a little. The cap will snap in place. Gently bend the rack tubing back in.
Nov 22, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ge pdw 7880 does not drain, even into a bucket straight from the outlet pipe
clogged strainer, clogged or kinked drain hose ,clogged pump, faulity motor,faulity drain valve. all can be disassembled and cleaned except motor & valve they need to be tested if u have a valve it can be repaired
Nov 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile dishwasher makes a humming noise
I had the same problem. The issue is due to the top rack water inlet not properly seating against the water line in the rear of the washer. I fixed it by placing heavier items (bowls, glass cups) on the rear of the rack and lighter items (plastic cups) near the front of the rack. As long as I arrange items on the top rack in this way the washer runs silently.
Oct 08, 2009 | GE GSD3800G - Multiple Color Built-in...
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Will not drain
the selenoyd is bad take front bottom cover off you will see the problem selenoyd with 2 wires conected to it
May 03, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
1,480 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
