I have a new toshiba satellite laptop. when i first bought it my touchpad worked perfectly but after installing logitech wireless mouse, my touchpad wont work at all. after trying EVERYTHING even uninstalling the mouse it still wont work.
  • 20 Answers
This is a definite driver problem that Logitech is guilty of. They install their driver and remove all aspects of any other driver but their's. This is wrong but they do it anyway. (This solution I rank for the NOVICE troubleshooter at least!!)
First, make sure that the driver for the mouse is completely removed by uninstalling it from the"Add or Remove Programs"section of your Control Panel. Doing it this way should make the right changes to your registry, but Logitech is known for NOT doing this. Next, reinstall the touchpad pointer driver software from the CD that came with your PC. There should be a Driver directory or driver install program on the CD. If not, go to the Toshiba website and, making sure that you use your model number and style type locate the drivers section. They are located under downloads or Tech section or something similar. Then find the latest driver listed for your touchpad. Usually, the driver is an executable and there are instructions offered to run the install.
After you install the driver and the pad works again, go to your registry (Run/regedit) (after backing up of course) and go to (edit/find) and type
Logitech into the box (Just Logitech). Then click "Find all".
an entry should appear that has Logitech in it. either delete the entry, or change its value to 0 if a value exists. (I would write down where the value is located in the directory tree). click "find next" to see the next listing, and remove it the same way and so on and so on until all values for Logitech are removed. Exit the registry, and reboot the computer. You should be all set at this point. THIS IS OF COURSE, THAT YOU HAVE NO OTHER LOGITECH DEVICES ATTACHED TO YOUR COMPUTER!!! IF YOU DO, THAN DON'T TOUCH THE REGISTRY AT ALL AND HOPE THE DRIVER INSTALL ALONE DOES THE TRICK !! If you are afraid to edit the registry, than find someone who is familar with it and let them remove the values. I never recommend anyone who is unfimilar with how the registry works to go into it and make changes. It is easy to edit the registry, but one wrong typo can keep you from booting your PC. Changing logitech entries won't cause this to happen, unless you have other devices from logitech attached, and even the most that can happen is these devices won't work. Your PC itself should be fine though
Posted on Nov 30, 2008
  • Frank Doll
    Frank Doll Nov 30, 2008
    Make sure that the startup file has had all logitech entries removed. Go to "Run" , type "msconfig" (No Quotes of course) and click the "Startup" tab. Deselect any entry relating to Logitech that you can honestly remove. Click "apply changes". It will ask you to reboot, do so. Select the "Don't show this box again" when the PC (laptop) reboots and there you go.
  • 106 Answers
1. CHECK IN DEVICE MANAGER THAT THE DRIVERS ARE PROPERLY INSTALLED.
2. RESTORE TO SOME EARLIER TIME.
LOOKS UR DRIVERS HAS GONE CURRUPT , DONT WORRY ITS NT BIG ISSUE, WILL BE RESOLVED.
Unlock toshiba laptop
Some toshiba laptops have trouble with the touchpad locking up. I have tried using a wireless mouse and it has helped whenever the touchpad locks up. to unlock (I'm assuming you mean log in) you can click space instead of using the mouse.
Sep 03, 2014 | Toshiba Computers & Internet
How to get the Toshiba satellite c 55-A-100 mousepad working aga
On my Satellite Pro P800 one of the F - Keys shows a small mouse if I press this it cycles the touchpad mouse feature on/off. I would guess your laptop has a similar feature. When all else fails read the on line manual. I hate the mousepad and always use a wireless Logitech mouse..
Jul 22, 2014 | Toshiba Satellite Computers & Internet
Touchpad not active
Press the "Fn" and "F9" keys simultaneously.
Test your touchpad. If it works, it was simply disabled. Press the same key combination any time you want to toggle your touchpad on or off.
Plug an external mouse into a USB port on your laptopicon1.png if the key combination didn't work. Follow onscreen prompts to install the mouse driver--if necessary. You can also move the cursor using the "Tab" key and the arrow keys, as well as click by pressing "Enter" until the mouse is operational.
Click the link in the Resources section if you are using a Toshibaicon1.png Satellite with Windows Vista. Follow the onscreen prompts to download and re-install the driver.
Open a web browser and navigate to Synaptics.com if you have a different Toshiba model or operating system. Synaptics brand touchpads are used in all Toshiba laptops, and this site provides a generic driver.Hover your mouse over "Support" on the top menu, then select "Drivers" from the drop-down menu.
Select your operating system from the list provided and download the generic driver
Follow the onscreen prompts to install your new driver, and then test the touchpad again. If it still does not work, take your laptop to a licensed repair technician.
Jan 06, 2014 | Toshiba SATELLITE 1905-S301 TOUCHPAD AND...
My touchpad and control buttons on toshiba satellite pro c850-FJ don't work
Contact seller. I'm a bit confused? Brand new Windows 8 install then Uninstalled ? Why? Is Win 8 still installed?
Feb 11, 2013 | Toshiba Satellite E205-S1904 Laptop
My toshia satellite C855-5214 touchpad not working but does with wireless mouse
I tried disabling/enabling touchpad by function key and also tried re-installing the driver but didn't work. then I applied windows updates and it started working.
Oct 26, 2012 | Toshiba Computers & Internet
Since installing a wireless Mouse and keyboard
Try reloading the sound drivers if you have not done so already.
Mar 16, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite L505D GS6000 mouse freezing
reinstall the driver for the mouse touchpad
Feb 22, 2010 | Toshiba Satellite A60 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
Touch pad refuses to work
Try going to Toshiba's support page and re-install the driver for the touchpad. If this does not work. You may need to replace the touchpad itself.
Apr 16, 2009 | Toshiba Satellite A135-S2386 Notebook
Touchpad do not work and neither the indicator leds.
You might check to see if the touchpad is locked.
Nov 15, 2007 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
71 people viewed this question
Alun Cox
David Payne
David Payne
