Question about World Marketing of America Heater- Blue Flame Natural Gas
1996 chevy monte carlo runs strong,idles rough
New egr,idle valve,plugs,and wires,first noticed problem soon after my daughter let it run out of gas.225,000 miles on car. Goodwrench told me number 5 cylinder,so I changed all the above.Still idles rough but as soon as you accelerate it runs very strong ,service engine soon light has been on ever since,approx 3,000 miles ago.
PS
Have'nt changed coil yet?
  • 586 Answers
Hold of on coil.
Basics.
Check the fuel pressure. I had this problem in a restore, turned out to be fuel sock in fuel tank or filter.
Check for vac. leak. Soap water at intake manifold and throttle body, injectors.
Then check plug wires at idle in the dark for minor crossover,
Now you can ck coil but i bet it is ok.
PS Check the linkage stops
Hope this helps if so let me know Thanks Mike
Posted on Aug 30, 2017
What does ERG mean on a citreon c4 coupe 1.6 diesel.
EGR - Exhaust Gas Recirculation valve. It takes a bit of the exhaust gas and runs it back through the intake. This helps clean up emissions.
Rough idle and loss of power are symptoms of a stuck EGR valve. The valves aren't too expensive, but labor varies depending on the model of car.
Jan 11, 2018 | Cars & Trucks
Rough idle 95 astro van, I did a full tune up , plugs,wires,cap, rotor,air filter,and fuel filter and cleaned egr vavle.
I actually had to replace my EGR valve and the gasket. I clean the valve well and reused both. I don't think the gasket sealed well enough though. So I went ahead and got a new valve, gasket and changed them. It runs a lot smoother now.
Dec 14, 2012 | 1995 Chevrolet Astro
1996 honda accord rough idle and dies
Do the following
Here are the most common causes of idle surge, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Aug 18, 2017 | 1996 Honda Accord
1992 Lumina Backfire - I have a 1992 Lumina Euro, 77K miles, 3.1 V-6. Under moderate to hard acceleration the engine will backfire and you can smell gas. The spark control module, coils, wires, plugs,...
I know you mentioned the EGR valve has been replaced, but you may have a bad 'new' part. I know the car is electronic, but has anyone checked its ignition timing (timing belt been looked at, I know it only has 77k on it). Is the fuel pressure regulator OK and it vacumm supply?
Nov 15, 2010 | Chevrolet Lumina APV Cars & Trucks
2003 f150 supercrew 2wd 4.6 romeo has 62000 miles.Pinging noticed when thermostat opens after cold start.Pinging occurs with most throttle positions/loads except full throttle (cant hear it) or idle.EGR...
do not use any fuel additives at all. and only use 87 octane fuel nothing higher. 4.6 and 5.4 ford engines do have a pinging sound especially with a load. but it is normal
Aug 19, 2009 | 2003 Ford F150 Regular Cab
The EGR vale is new, it it is rough idoling or driving..i drive about 104 miles a day..it use about 1/4 tank gas per trip. (new plugs) they are fowled out .. i pulled the wires one ata time no change in...
SCAN IT TO SEE IF YOU HAVE MAP SENSOR WORKING.ALSO CHECK VACUUM LINES GOING TO MAP SENSOR MAKE SURE ITS NOT. BROKE OR CRACK.CHECK COILS RESISTANCE.BAD COILS CAUSE ROUGH IDLING.SCAN MAKE SURE COOLANT SENSOR ISNT OPEN.REMOVE EGR VALVE. CLEAN OUT CARBON IN THE INTAKE PORT.USING A PIECE OF CLOTHES RACK.CLEAN UP DEBRIS.ALSO CHECK FUEL PRESSURE REGULATOR.CHECK VACUUM LINE TO FUEL PRESSURE MAKE SURE ITS NOT FULL OF GAS.AND DONT HAVE CRACKS IN IT OR BROKE.
Jun 06, 2009 | 1994 GMC Sierra
Runs rich, loads up, hesitation
It could be several things but most of the time with these its a faulty EGR valve that causes the off idle sputter. You can take a piece of tin soda can and bolt it between the valve and intake. If the probelm goes away then the EGR valve is at fault.
Aug 17, 2008 | 1993 Chevrolet Suburban
Stalls after it runs awhile,
egr valve is open, have it checked.it might be the egr valve itself or the siolinoid
Jul 22, 2008 | 1995 Pontiac Sunfire
World Marketing of America Heater- Blue Flame Natural Gas Logo
42 people viewed this question
Top World Marketing of America Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
Are you a World Marketing of America Heating and Cooling Expert? Answer questions, earn points and help others
