Question about Rainbow E series Canister Wet/Dry Vacuum
E series How did you take your rainbow e series apart? Do you have a manual? I've got a few pieces off mine but can't see where any other screws are to completly take apart to be able to look at motor. Thanks Kelly
  • 11 Answers
The clear lenses on either side of the top part of the E-series Rainbow are removable. If you look at the each lens you will see two sections on the top edge of each lens that looks like this |___| |___| about 1 1/2 inches in from each end. Put a small screwdriver in the middle of each one of these (I used 2 screwdrivers at once) and pry out. The clips will come undone and you can remove the lens this way, exposing the screws which hold the motor cover on. On my E-2, there were 4 screws under here, and once I removed them, the top came right off.
Posted on Mar 06, 2009
I don't have the manual. I never could get to the actual motor. I just cleaned it out and changed the belt and it has been working fine ever since.
Posted on Nov 30, 2008
How do I get the motor out of the power nozzle on the E-series?
The eSERIES Rainbow has several versions of the power nozzle. Some screw apart and others have snap connections. Look at our website on the manuals page to determine your model. You can also call us and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Jun 02, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Don´t know how to take my Rainbow apart.
Your model is a bit newer than mine, but on mine, I have to peel off the foam rubber gasket that seals the canister to the top of the vac when you put it together. You will have to replace this gasket once you peel it off. Under the gasket are the screws that hold the top cover on.
Hopefully your model is similar to mine, and this is the answer you need!
Nov 06, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I want to take the vac apart to clean around the motor ?
likely a break in your cord somewhere. if you have a ohm meter check it otherwise tale it to a vac repair shop
Oct 25, 2008 | Rainbow E series Canister Wet/Dry Vacuum
I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Jul 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
did you ever find out the problem with your rainbow? Mine did the same thing today- turned on the switch yet nothing happened. Think it needs a new switch???? Do you know how to get canister apart after taking out first screws?
Jun 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
I can't take apart the Rainbow Rainmate to clean it.
The E series has a clear plastic window on each side that you remove to get to the screws, remove them and it will come apart. Some will have tabs instead of screws.
Mar 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
Jan 04, 2008 | Vacuums
Rainbow E series Canister Wet/Dry Vacuum Logo
360 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
