Question about Cameras
I connected the wrong charger to my camera it turned on for a sec then turned off and it dont turn back on no more
  • adrian j Nov 30, 2008
    well thank u do u know were i can go get the website repair facility
    Problem Solver:
  • 16 Answers
You may have done some real damage to it. Usually this will only happen if you use a charger with a higher output then the correct charger. Compare the wrong charger to the right charger and if the output on it is higher you probably overloaded it. If that is the case you can check the manufacturer's website for their authorized repair facility near you but sometimes it's cheaper to buy a new camera.
Hope that helps!
Jill
Posted on Nov 30, 2008
  • Jill Grusak Nov 30, 2008
    I can help you find that if you post the make and model of your camera.
I CANT FIGURE OUT HOW TO TURN THE CAMERA ON WHILE CONNECTED TO WALL CHARGER.
hi,
there may be a slide switch on the charger side, slide it to VTR position then power on, it will work.
Apr 05, 2016 | Video Cameras
My computer does not turn on, what is wrong?
try to do this:
- remove the battery and charger (everything
connected to the pc) then press the power button
for 1 minute.. - plug back in the charger - after few secs try to turn it on
hope this helps :D
Mar 23, 2011 | Acer Aspire 5535-5050 Notebook
I was tring to charge the camera M1073IS by mistake i did put a charger that has 9V instate of 5V the screen went bright wight for about 10 seconds and then i took the charger off and put it back again not...
Well, that was nearly double the voltage required for the camera. Usually you cant even plug in the wrong charger.
In this case, you may have destroyed the camera's battery.
To test this, you can go to an electronics store for them to test, or you can purchase a replacement battery (hang on to the receipt) and if it does not work in the camera, you may return it. Be sure to ask someone in the store if they accept opened packages, explain the situation, and be sure that is within their return policy.
If the new battery does not operate the camera properly, it is entirely possible that you overpowered the camera beyond its tolerances and it would have to be repaired or replaced by Kodak.
Sorry I dont have better news.
Cheers.
Feb 23, 2011 | Kodak EasyShare M1073 IS Digital Camera
I got new nikon coolpix s4000 digital camera(black).it automatically switched off.i chang its battery,charger but it dont works.please help
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 03, 2011 | Nikon Coolpix S4000 Digital Camera
My laptop is an Asus 1005HA-V and I'm having trouble turning it on. I've had it for about a year and when I try to turn it on it's lights flash and then turn off again. Also sometimes when it's on the...
Things that you can try:
1. disconnect the charger and the battery. 2. press and hold the power button for 15 secs. w/o the charger and the battery (the reason for that is to drain flea power). 3. connect the laptop straight from the charger w/o the battery and turn it on. It should turn on fine. If nothing happens, the motherboard is bad or the charger.
Jan 17, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have charged my camera but it will not stay on when turned on
you dont have explain exactly the problem.. if the problem turn on and off istantly this is shure a lens problem and you mst change the lens. if the camera turn on one two 3 minute and than turn off its probably that the camera dont charge the batterie. if the camera dont charge you can bypass the problem. you can buy on ebay a external charger for your batterie. if you search on ebay international seller you can find charger and batterie to a very good price. its possible to find two batterie and one charger to 10 sterl. so you have new batteries and a external charger. external charger is better as charge the battery in the camera. why i is nott so difficult that the batterie explode and ruine the camera. with a external charger this is not possible why you can ruine the charger that have a low cost but not the camera. i hope that i have help you. its possible that the camera dont charge its possible that the batterie dont mantain the charge.. its possible if the camera go on and go out directly that this is a lens error.. sorry foer my english
Aug 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Mar 05, 2009 | HTC G1
Camera dont come on
The battery or the camera itself may be faulty, take the camera back if you bought it new
kind regards and please don't forget to rate us
Dec 08, 2008 | Jazz DV-179 Digital Camera
VPC-T700 Wont Turn on
hiak, I had the same problem with my camera. Try opening the battery cover and pressing down onthe battery while turning on the camera. If the camera turns on you have a poor conection between the battery and the camera.I folded a small piece of paper and put on top of the battery then closed the cover.Its worked like new since.
Oct 07, 2008 | Sanyo Xacti VPC-T700 Digital Camera
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
