Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Can't get the retaining ring back in on MOEN Magnum Replacement Cartridge
  • 1 more comment
  • Ray Coon May 11, 2010
    I assume that you are talking about the Horseshoe clip taht hold the cartridge in place.
    When you removed the old cartridge did it remove easily and cleanly or did it seperate some of the rubber pieces that go over the waterways of the catridge.
    The valve must be cleared of all debri and must seat all the way in.
    Also, once in place it may be neccessary to turn the cartridge back and forth slightly until the retaining clip is completely lined up with the slots.
    Once you have installed the cartridge and if the hot & cold waters are reversed it is not neccessary to remove the cartridge instead just take hold of the brass part of teh cartridge and rotate 180 degrees and that will reverse the hot & cold water.
    Good luck1
    Hope I have been of assistance.
  • James Feragola
    James Feragola May 11, 2010
    Ok, sorry missed the model number in the subject line of your post.
    This is the correct diagram for your body. 3175 Legend
  • James Feragola
    What is the model number for the shower body?
    Make sure the valve is seated all the way and is aligned properly, it should slide in with no problems. Diagram.
    Problem Solver:
  • 13 Answers
Make sure that the stem is slightly pulled out or open then use the plastic insertion tool that comes with the new cartridge and a pair of pliers to push cart. all the way in. Try the retaining clip again. If still won't go, partially install the insertion tool and turn cart. back and forth til clip goes in. Hope this helps
Posted on Feb 07, 2009
Moen 87786 Kitchen Faucet, seized and now Broken cartridge retainer ring/nut removal?
get in a plumber to remove the unit and have anew unit installed
Feb 20, 2018 | Moen Plumbing
How do i install a moen stem replacement kit part 97479?
make sure you turn the stop under the cabinet off use an allen wrench to take the handle off pull the keeper off the old cartridge pull the old cartridge out and make sure you put stem grease on the o-rings before installing the new cartridge or you will cutt the o-rings and ruin your new cartridge. put you keeper back in and reinstall your handle. turn your water valve back on underneath and enjoy.
May 04, 2014 | Moen Plumbing
We have a 20 year old tub shower single valve. We replaced the brass cartridge with a plastic cartridge and water is leaking out of the front when the water is on. Do we need to replace it with a brass...
I'm not now nor have I ever been a fan of the plastic moen replacement cartrideges. I don't know if they still do but probably about twenty five years ago I tried using a few of the plastic replacements,mostly due to high cost of the brass moen factory ones I think every one leaked. Then I actually read on the instructions that it was not unusual for them to leak some. My suggestion is to get a good brass moen magnum cartridge and be done with it for another twenty years. Hope this helps you. Thanks.
Nov 17, 2010 | Moen & Replacement Cartridge
How do I remove the cartrige from the valve?
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
Jun 03, 2010 | Moen & One Handle Tub & Shower Faucet
Followed replacement procedure for moen posi temp shower valve (turn 45 degrees ctr clockwise after removing retainer and pull) valve will not come matter how hard i pull..what next (solution ???)
Often time a Moen cartridge becomes very fond of it home and doesn't want to leave. I once stood on top of a kitchen sink just to get my back into it to remove a cartridge. That is a rare example.
Once the retainer clip is removed there is nothing to keep the cartridge in place except water minerals, lubricant, and suction caused by the lubricant. Frequently it will take a rocking back and forth of the cartridge to fully free it from it's confines before a good tug. If you don't use the white plastic tool that comes with the new cartridge, you could pull the center stem out only and that's all bad. Before installing the new one see if you can have someone turn on the house water for an instant while you hold a cup or glass over the hole for the cartridge. This will flush out of the valve body any particulate that might affect your new cartridge. The cup will help keep you and your bathroom floor dry.
After inserting the replacement as far as you can, place the tool back onto it and tap on it to make sure it is in all the way. Then use the squared end to put a wrunch on to you can turn the cartridge internally and align it for the retainer clip.
May 21, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
Moen 87135C leaks - I've replaced the cartfidge (Lowes didn't have O rings) and put it all back together - but it still has a leak - I guess I should try the O rings - Does o-ring replacement involve...
If you call Call: 1-800-BUY-MOEN (1-800-289-6636)
8:00 am to 8:00 pm Monday thru Friday
8:00 am to 6:30 pm on Saturdays EST. and give them model number they will send you the parts.
Oct 04, 2009 | Moen & Replacement Cartridge
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
After consulting with Moen re: 2 knob Tub "cartridge" replacement, 12 yrs old, cold water not running, I did what I was told, after receiving the replacement cartridge 1248. (warranty replacement) The...
If the water is off but still coming through, open a tap or two on one of the lower levels.
Basically the old stem does come out thru the top of the valve. Hopefully Moen sent you the tool to do this job. The tool is a 3/4"diameter about 4 inches long. Even on one end and two little tabs on the other.
Take the handle off stem. Remove the upper retaining nut, usually chrome. Pull out the two plastic upper stem pieces. Insert the 2 tabbed end into the stem area. You will feel the tab drop into the retainer ring. Slowly rotate the retainer ring out Counterclockwise. After the retainer ring is out then put the long screw in the stem and pull it out. Sometimes a little leverage helps here.
You will have TWO retainer nuts. The first one is easy just under the handle, the second will require the special insert tool.
Please rate this response and good luck, Phil
Dec 29, 2008 | Moen & Replacement Cartridge
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
449 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
