Question about Water Heaters
Water Heater Heating Problem
We just bought a 50gal water heater 2 months ago. Now, the water will stay hot for about a minute and then get luke warm. Suggestions?
  • James Feragola
    James Feragola May 11, 2010
    Is the water heater electric, gas or oil?
  • 42windowman May 11, 2010
    no response from you as yet- I do have a few ideas but require some questions answered
Shower heater panasonic cant heat
Posted on Jan 31, 2009
    Sergeant:
  • 359 Answers
I guess it is electric ,check bottom element reset button .remove bottom cover with power off look for a button on bottom thermostat or limit if find push it to reset ,,then set the thermostats , set top to desired temp and the bottom at least 10 degrees more ex. top 130 bottom 140 this might prevent problem reoccurring if this not problem bottom element could be burned out.replace ele
Posted on Dec 02, 2008
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
Oct 14, 2014 | Water Heaters
Eemax280t2t no hot water
see if the circuit breaker switch has tripped either partially or fully and reset it. Check for bad or loose wiring on the heater and breakers. The next thing is more likely the heating element is no good and needs repaired or the heater needs replaced.
Jan 30, 2014 | Eemax Water Heaters
I have abosch 1600 ps aquastar 4.3 gpm indoor when i turn hot water on it all fires up but no hot water comes out only luke warm water why
Water heater is heating water but only luke warm water arrives at faucet.
Open TP valve and confirm that hot water is available.
If water at TP valve is hot, then problem might be plumbing-related, for example crossover.
http://waterheatertimer.org/Crossover.html
Aug 15, 2011 | Bosch 1600PS NG Aquastar 4.3 GPM Indoor...
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
Water just gets luke warm on propane or electric. has electronic ignition, do i need circuit board? Atwood 6 gal. tank
Run it on propane and let water heater go through a heating cycle, and when it shuts off, CAREFULLY , pull the lever on the pressure relief valve slightly and see how hot the water feels there. If it's hot there, then it's more than likely a problem with your by-pass valve(s) at the back of the water heater. Either in the wrong position, or faulty, and allowing hot and cold to mix. If in doubt which one it may be, you may be able to remove by-pass set-up completely, depending on what system you have. What the ultimate goal is would be to attach your incoming cold line directly to bottom fitting of water heater, and outgoing hot line, to the top. Not unusual in some systems for one of the shut-offs in between the 2 lines to stay partially open, and allow cold to mix with hot, thus -warm only. If it's not hot at pressure relief valve, then I suspect a faulty thermostat, but that would mean they both (hydro and gas) would have to be faulty which is unlikely.
Jun 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
Extreme hot water then to consistent luke warm
Possible thermostat problem. Are you experienced enough in that area to do some testing. Have a multimeter? If not experienced, don't try it, too dangerous. Call in a service person.
Mar 07, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a reliance 501 electric hot water heater and i cant find the reset button. Where is it located?
it is located on the thermostat. Take the cover off the side and you will see a little red button in the side of the themostat.
Jan 10, 2010 | RELIANCE ELECTRIC WATER HEATER
We just bought a Whirlpool Electric 50 gallon water heater 2 months ago. Now, the water will stay hot for about aminute and then turn luke warm. Suggestions?
You need to be skilled to work on live electrical appliances. If you are I can continue. If not you need to call a electrician or a plumber.
Make sure both thermostats are set at the same temperature. Let me know what you find.
Nov 30, 2008 | Water Heaters
Water Heaters Logo
125 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
