Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Repainting doors on whirlpool white refrigerator
Rust spots on freezer and refrigerator doors. What kind of paint should be used for sealing rust and repainting?
  • Whirlpool Master
  • 2,651 Answers
Oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
Posted on Nov 30, 2008
  • Steve Mar 24, 2012
    Rust from the inside out can't be fixed.
    This is a common problem with whirlpool refrigerators. They are poorly finished.
  • jeanne hennessey Oct 03, 2013
    i am having the same issue with a 6 year old Amana refrigerator, the bottom freezer door has dots of rust on the white textured front. sanding/repainting will probably look even more horrible. $300+ to replace the freezer door.
Freezer door is rusted at base of the water and ice dispenser. What causes this?
Rust is cause by presence of water
you either have condensation (due to we insulation) or some kind of water leak.
Jul 21, 2014 | Hotpoint HSS25GFP Side by Side...
Brita profile
yes replace the seal, this type of spotting that forms as rust color occurs on "ferritic" stainless steel. Simply put there exists iron in the alloy and the surface needs to be pacified. Use DeBruce Polish to correct the problem. Non-toxic and odor-less containing NO ACID, this TRUE MULTI-SURFACE CLEANER is the best product for stainless steel AND glass/ceramic cook tops. Go to, you will be glad you did!
Aug 26, 2013 | GE GDS18LBR Bottom Freezer Refrigerator
Spray paint on metal door cracked in some spots. first coats were fine and then just a few place cracked. how can we fix this?
Repainting without adequate drying time will cause this. Make sure paint is dry. Use 180 grit sandpaper in swirling pattern to sand down the problem areas, idea is to feather edge the paint so you don't feel and ridges between the transition layers when you sweep your hand over them. Then prime the bare metal, then repaint entire door for best results.
Aug 13, 2013 | Rustoleum Rust-Oleum - 1685830 - Spray...
Door on freezer appears to have rust pittiing spots
fridge/freezers are only painted on the OUTSIDE,the interior has only got primer,so if kept in a garage or any high humdity area rust will occur.(from the inside out,like a car)NO CURE......thats the way makers get you to buy new.....
Oct 03, 2010 | Whirlpool Refrigerators
Get your refrigerator repainted before it is too late. It isn't that costly. Cracks may be due to rusting. Ask those mechanics about it when you give it for painting.
Apr 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Microwave safety after repainting
Too generic...Did you use the high-temp appliance enamel recommended, or a spray...or worse?
Was the rust inside where it can contact food through the circulating air, or on the outer body?
First thought based on how I read the question: Never use that machine again...but that's based on the word "in" instead of "on my microwave".
If the rust was around the door frame, outside the seals, and you used an enamel (of course) then you may be OK...but...
Considering the fact that a cheap microwave is a drop in the bucket when compared to your family's health...Why risk it?
Mar 29, 2010 | Welbilt MR622W Microwave Oven
Rust on outside of freezer door -- is there an epoxy or white coating to cover over the rust?
You can clean off using a green scrubbing bad and some brasso all at wall mart then buy a can of spraypanit and spray it with food grade paint by Krylon paints also at wal mart. The paint will seal it and keep it from comming off.
Nov 12, 2009 | Amana ABB1927DE Bottom Freezer...
The paint on the front of my Whirlpool refrigerator has rusted in spots near the door handle and the rust is spreading. What to do?
You can purchase a bottle of rust converter at any auto parts store, and then all you need to do is purchase appliance paint..
Jul 18, 2009 | Refrigerators
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Dec 01, 2008 | Refrigerators
Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Jun 11, 2008 | Jenn-Air JCD2389G Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
1,305 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
