Question about George Foreman GV5 Indoor Grill
What are the trays for
The plastic removal tray is obvoiusly the drip tray but what is the metal removable tray with side plastic handles in the top of the GV5 GF grill oven?
Is it a cake tray and do I take it out to cook chicken etc?
Dear ravirtue, the metal removable tray is for cooking dishes where you want the liquid to not drain away such as gravy on meats. You can use it to make stews or chili or meatloaf. It can also be used to bake with such as , yes, cakes or cinnamon rolls. It comes in quite handy. I've used it to do chicken as well when I didn't feel like having to clean the whole machine. Hope this helps you out. Enjoy your roasting machine. It makes the best tasting chicken, fried but without all the grease of doing it in the frypan. Good luck! Wackybird12
Posted on Apr 10, 2009
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
Feb 21, 2012 | Refrigerators
I have a kenwood KDW12ST3A dishwasher. i have lost the manual and the dishwasher is displaying code E4.What does this mean ??
HERE IS A LEAK AND IT IS BUILDING UP IN THE BOTTOM DRIP TRAY!. It is filling up the drip tray and tripping the micro switch. Remove the lid(2 screws at rear),givng access to screws on top of right side panel,remove right side panel, you will have to remove plastic cover on bottom front first to give access to screws on side panel. This gives access to the hoses and such, where the leak is most likely coming from. I would buy some inch and a half to 2 inch hose clips first, as the clips on the machine are not really reusable.The machine will have to be put on its left side, you may have to remove the bottom drip tray also, this holds the micro switch and the polystyrene float. You may have to run the machine to see where the leak is coming from, It is time consuming, but very "doable", remember electricity and water do not mix,unplug and make sure everything is dry, particularly yourself!.
Apr 26, 2011 | Dishwashers
New Royal Professional Machine has the workd Dregraw.miss can not use the machine what must I do to get started need help.
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Jan 10, 2011 | Saeco Royal Digital Plus Coffee...
Have an 8yr old Kenmore top freezer. Water is dripping from top of refrigerator section,from back right side of a vent. Have made sure food is not blocking circulation in freezer. Help!
Your freezer has a drain tube located behind the: freezer ice tray back rear plastic cover; It leads to the defrost tray at the bottom of the refrigerator. remove the back rear plastic cover, the drain will be located at the right side of the coils.
flush the tube out using a funnel and, a pan of hot water. empty the floor defrost tray as you do this.
Mar 30, 2010 | Refrigerators
My icemaker fills the tray but when the water shuts off it drips on the the ledge under the tray and ice builds up. Also now my ice cube tray seems to be leaking.Are parts available or does the entire unit...
My ice maker would not return to a level position after dumping out the ice. When the water turned on to refill the ice tray, it would run off the tilted ice tray and into the ice basket thus freezing all the ice cubes in the basket together. To remove the icemaker, there are two screws that hold the icemaker to the top of the freezer. Turn off the icemaker. Remove the left screw and loosen the right screw by removing the screw on the left. Slide the icemaker outward and it should come loose. Unplug the power connector from the icemaker to the freezer. The ice tray can be removed from the icemaker by gently pulling the tray to the right and the slot it goes into on the left side of the icemaker to the left. Once the tray is out of the assembly, inspect the round plastic shaft on the left side of the ice tray. Mine had two flat spots that were worn into the plastic from use. I used a dremel tool with a round barrel sanding disk at the tools lowest speed to remove the flat spots and decrease the overall diameter of the shaft which stopped the tray from sticking. Reassemble the ice tray in the icemaker.
Mar 10, 2010 | LG LSC26905TT Side by Side Refrigerator
When I switch on an error is occuring : Dredgdraw
Hi
The white thing on the side is for the cappuccinatore. It slides on with a twist. The hose goes into your milk. You twist the little knob on the top when it is steaming until the milk goes up the tube and produces the foam. Once you get the foam going you won't have to move the knob again. Just keep everything clean.
Dec 29, 2009 | Saeco Royal Professional Espresso Machine
I have a Saeco 21103 unit and it keeps getting an error message of ''dregdraw Miss'' what is that?
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Oct 27, 2009 | Coffee Makers & Espresso Machines
Locked dvd tray
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Mar 29, 2009 | Televison & Video
How to change battery?
Remove all the case screws, except the rubber feet. Remove the handle. unplug both batterys, seperate the two halves of the case. A plastic tray seperating the two batteries will be preventing the removal of the bottom battery bracket screw which is metal. I drilled through the plactic to enable a long screwdriver to remove the bottom bracket screw. An extendable magnet was used to retrieve the screw, although not necessary. The top battery bracket screw can be removedat any time once clearance is gained. . What a PITA, stupid engineering!
Nov 18, 2008 | Air Tools & Compressors
Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
Mar 10, 2008 | Refrigerators
George Foreman GV5 Indoor Grill Logo
288 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
