Question about Water Heaters
We just bought a Whirlpool Electric 50 gallon water heater 2 months ago. Now, the water will stay hot for about aminute and then turn luke warm. Suggestions?
  • pete50 Jan 06, 2009
    I have exactly the same problem with mine I bought in June for a new home. We did not move in until October so it has only been running two months. Replaced the electronic control unit with no effect. Repair guys says it is not the water heater and plumbing company says it is not their problem it is the water heater. Did you ever get yours fixed and if so can you share the solution?
  • Anonymous Mar 28, 2014
    turns off
  • 61 Answers
You need to be skilled to work on live electrical appliances. If you are I can continue. If not you need to call a electrician or a plumber.
Make sure both thermostats are set at the same temperature. Let me know what you find.
Posted on Nov 30, 2008
Have 40 gallon electric hot water tank 10 gauge wire 20 amp double pole breaker federal pacific fuse box red black ground wire shows power on 2 hrs now not even Luke warm water what could be wrong
I'm an electrician and can help. Federal Pacific equipment is tough stuff. The company went out of business decades ago - due to faulty equipment they made. Aside from that..
There may be no power out of the breaker, bad connections between the breaker and water heater, bad thermostat, bad hi temp sensor, bad heating element and more. I wrote the article linked below - that will help you find and fix any of these problems and more - assuming you have the equipment and ability to work on electric water heaters. If not - call a licensed electrician.
How to Repair an Electric Water Heater
Jun 05, 2015 | Water Water Heaters
Atwood gc10a-4e only producing luke warm water
make sure bypass on back isn't open or half open then see if mixing valve on shower or outside shower off if all ok possible bad temp sensor
Feb 19, 2013 | Atwood Mobile Products Atwood 10 Gallon...
Rheem electric water heater 50 gallon, lukewarm water. Water is warm but not hot, where should we look for problem?
Luke warm water is the result of top element bad and the bottom is the only one heater. The best solution I can reccomend is to change both out due to the fact the bottom element may go bad and since you have to change one you might as well change both.
Turn power and water off, drain heater down and once water is drained out change them out. Once new ones installed turn water on to fill heater and open faucets and get air out on the hot side of each faucet once water is flowing out of each faucet you are now ready to turn power back on.
Oct 12, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
50 gallon electric heater not working after about 5 minutes in the shower the water gets cold and the rest of the house i do have 240 going to water heater thermostats goood element good
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
May 21, 2010 | Water Heaters
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Extreme hot water then to consistent luke warm
Possible thermostat problem. Are you experienced enough in that area to do some testing. Have a multimeter? If not experienced, don't try it, too dangerous. Call in a service person.
Mar 07, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Mar 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heater Heating Problem
i guess it is electric ,check bottom element reset button .remove bottom cover with power off look for a button on bottom thermostat or limit if find push it to reset ,,then set the thermostats , set top to desired temp and the bottom at least 10 degrees more ex. top 130 bottom 140 this might prevent problem reoccurring if this not problem bottom element could be burned out.replace ele
Nov 30, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
