Question about Goldstar DV7411N DVD Player
GOLDSTAR DVD/VIDEO PLAYER
OUR DVD PLAYER IS STUCK IN 'PROGRESSIVE SCAN MODE AND WE CANT PLAY DVD'S ... WE TRIED RE-BOOTING IN WHICH DIDNT HELP. WEVE LOST OUR MANUAL...ANY SUGGESTIONS OUT THERE?
  • Anonymous Mar 26, 2014
    wont work just stuck on 0000 in the screen tried everything please help
  • 4 Answers
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Posted on May 20, 2007
Take your dvd player (and remote control)to a HDTV and Plasma/LCD sytems store and ask them to permit you to plug it into a Video Screen that either has 480P input facility or a tv with "progressive scan " auto recognition. You can't see how to fix the problem using your own TV because it doesn't recognise "Progressive scan". Once you have the picture up on a compatible display unit at the shop, use your remote control to access the appropriate "Display Setup Menu" and return it to the "normal" display mode setting. It should now work ok when you get it connected back to your own TV at home. Good luck, ooh and be extra nice to the store staff!! They muight learn something they can use to advantage!
Posted on Sep 08, 2007
I am stuck in the Progressive Scan Mode on my DVD player & cant get it out of the blue screen. I have tried reseting it & even unplugging the player.
If your TV does not support progressive scan, you won't be able to get out of the blue screen. The only way to solve this issue is to connect the unit to a multistandard TV which has this capability, then in the player's on screen menu, look for anything that would allow you to select either progressive or interlace as its video output (or has progressive on and off feature) - and switch progressive 'off'. This should revert the output back to interlace. Then unplug the combo, reconnect it to your original set, and it should work fine after that.
Not impossible to correct, but a real pain if progressive is selected in a DVD player's output and the TV does not have that feature. Some DVD players have progressive output as a default option in their setup. Reverting it to interlace or turning it off so it matches the TV it is connected to should solve this problem.
Feb 16, 2011 | Goldstar GBV241 DVD Player/VCR
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Issues with my goldstar
Goldstar dvd/vcr combo was stuck in progressive scan. I used the posted solution and now it is out of progressive scan but it continuously reads the dvd and I cannot get the dvd to play. "Reading" conitues to appear on the screen. Any suggestions?
Thanks!
Patsy
Dec 29, 2007 | Goldstar GBV241 DVD Player/VCR
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
GoldStar DVD/VCR-progressive scan mode problem...``
Remove any DVDs from the disc player. You should be in Blue Screen mode on the TV...If it says "Progressive Scan Mode" ....make sure there is no DVD in it...close the disc changer and push and hold the "Stop" Button on the player, not the remote, for 5 seconds or longer. This has been proven to work every time!!!
Apr 10, 2007 | Goldstar GBV241 DVD Player/VCR
I'm stuck in Prggressive Mode on my RDR-VX515
pressing and holding the PAUSE button on the front of the DVD player for 5 seconds. (this is the one that worked for me) Hurray!
pressing the PROGRESSIVE button on the front of the DVD player or P.SCAN button on the remote control to disable the progressive signal.
power off the DVD player and press 369 using the number buttons on the remote control, then power back on the DVD player.
moving the VIDEO OUT switch on the back of the DVD player to the INTERLACED position.
Dec 11, 2006 | Sony RDR-VX515 DVD Recorder/VCR
GBV441 Goldstar DVD Player / VCR Combo
this is the right solution, the solution in the User Manual doesn't work
Nov 04, 2006 | Goldstar GBV241 DVD Player/VCR
DVD/VCR stuck in Progressive scan mode
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS. Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk. Try it & Good Luck!!!!!!!!
Nov 02, 2006 | Zenith XBV442 DVD Player/VCR
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
Goldstar DV7411N DVD Player Logo
334 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
