Question about Kitchen Ranges
I cannot put the door back on our Electrolux gas oven
I saw your post and need some advice on putting our oven door back on our gas range. Can you please help?
Thanks!
priyabrat
  • 123 Answers
SOURCE: We took the oven door off and now can't put it back on
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Posted on Feb 13, 2008
  • 1314 Answers
SOURCE: Electrolux Oven burner
1st thing to try is pull out the bottom drawer there is a gold safty valve there with two wires on it turn on the oven count to thirty then with the end of a screw driver the plastic end rap it a few times smartly and let me know what happens
Posted on Feb 15, 2008
SOURCE: Whirlpool super Capacity 465 gas range-Door Lock
your latch is defective. they have parts that melt when you use the self cleaning cycle. they also just go out. the door should auto latch when you start the cycle but it times out when it is not seen.
Posted on Feb 20, 2008
jsrock516
  • 5911 Answers
SOURCE: Oven won't light, burners and broiler work
Here ya go...
The same method applies to both the broiler and bake manifold:
1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
6. Unplug the old igniter and remove the mounting ***** holding it to the gas manifold.
7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
8. Reconnect the wires using the recommendations mentioned in Step 5.
9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
NOTE: Most igniters cost around $50. Prices will vary with models. I hope this is the information you needed.
Posted on Mar 11, 2008
Just tried out the self cleaning and got this error.
Got this same error right before last thanksgiving and the door was locking and unlocking erratically and oven wouldn't heat. The only solution to get rid of the noise that we had at the time was to turn off the circuit breaker for the oven.
When we lifted up the top panel and cross referencing the wires with the online diagrams (Googled model number shown when opening drawer which got me to diagrams on http://www.partselect.com/) and my wife notice a hanging wire and said perhaps it shouldn't be hanging and it should plug into something. plugged it in as diagram shows and made a great turkey.
So I'll open this puppy up again and see what I can see and ask my wife to lend her keen eyeballs again ... if I don't post then we failed.
Good luck to the rest of you.
Posted on Mar 29, 2008
Oven won't heat after attempt at self clean (self clean did not run)
Kindly check the heating element area esp.. the thermal fuse, and also the temp control for any problem..
Thank you
Jun 02, 2008 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
Hi. The outer glass grill door has come away and smashed on the floor when going to open grill by the handle. Can't see that there were any screws in the bottom of this. Would they have been factory...
Sometimes the glass is bonded to the door (glued) which may be why you can't see any screws.
It seems as if you are going to need a new grill door complete.
Dec 30, 2009 | Electrolux EOG9330 Gas Double Oven
Putting on the oven door of a whirlpool gas range
You may need to pull the hinges away from the oven front to their first rest. That should allow for standing the door back on.
Nov 08, 2009 | Kitchen Ranges
My oven door fell off.
You need to put door back in the hinges , pull it up and slide it back.
If door does not fit, you may need to have hinges replaced.
See diagram below , click on picture to enlarge:
Mar 28, 2009 | KitchenAid KGST307 Gas Kitchen Range
Can't put oven door back on
Hinge has a small hole in it. Lay door flat on rug. Take a pair of channel locks and tension hinge past hole. Put a screw in hole to hold it open. Then put door on product. Remove screws. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool GS460 Gas Kitchen Range
Here ya go...
Mar 11, 2008 | GE Profile JGS968 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
