Question about Mitsubishi WS-65908 TV
Tv shuts off but when i open the covers to let air in it stays on
  • 121 Answers
Commen prob solid state equip. heat sen comp prob horiz circuit need tech or insall small fan .
Posted on Dec 01, 2008
Mitsubishi TV, WD 60735; TV shuts off shortly after powering up.
It could be but a couple of other possible reasons---they had problems with this set and its brothers with caps in the main power supply puffing up and causing this "hard to turn on" issue.
A second reason is dust/dirt inside the unit.
All air is coming in via the front of the set and exits the rear--enough dust gets inside and the fans slow down or the lamp gets too hot and set shuts down---don't try this in the house: we take them with back cover off outside the building (on a ramp) and with air clean them out completely--try not to blow it inside the screen. It looks like a dust storm in most cases but can cause exactly the problem you have.
Apr 23, 2012 | Mitsubishi WD-60735 Projection Television
My Samsung TV HLS4288W shuts off by itself. When I turn it on it repeats with the same, shuts off. I have to repeat this process several times before the TV finally stays on.
There's a loose connection in the power supply of your television.Try to fix this problem.If you want to do the repair,just open the back cover of your TV and look the power supply.Try to resolder the board of the power supply and check the connector to power supply from the board supply.You can power on the televisions while the back cover is open to see that the power supply is working. Thanks!!
Aug 21, 2011 | Samsung Televison & Video
Goes into protection mode and shuts down
Audio IC main outputs are shot my dear friend ... if you plug your headsets this automatically disconnects your main speaks ... unit should stay on . Once you unplug headset it goes back to main automatically protection is displayed and shut unit off ... going into protection mode is just so the short in the unit won't burn out other stages of the output sector. but outputs must be replace .
Feb 15, 2010 | Samsung HT-X50 System
My TV turns off. As soon as I turn it back on it
try the lamp door switch in the back of the TV, door is held on by 1 screw, after door is open there is a blue switch by the slide that protects the lamp. push the switch down and up a couple of times then put cover back on and see if tv stays on. this was my problem with this exact tv.
Dec 17, 2009 | Samsung HL-S5086W 50" HDTV
SAME HERE I HAVE A 52 INCH SONY HDTV AND SHUTS OFF CONSTANTLY
Is the tv and receiver in the same cabinet...or an area where the heat from one can affect the other. If so...you may have overheating. Also, be sure that airflow around the TV is good and that any air paths are open (enclosed cabinets can be bad news)
Jul 18, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My TV shuts itself down by itself
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Disc door will not stay closed
try blowing dry air by the disc port, to clean the reading eye(pickup),(get a can at radio shack),prices of today put you to think abouth repair or buy a new one, you decide...good luck
Aug 09, 2006 | Apex Digital GT1417DV 14 in. TV/DVD Combo
Mitsubishi WS-65908 TV Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
