Question about Linksys RangePlus WRT100 Wireless Router
Wrt 100 router no showing
Trying to hook son's computer wirelss to the wrt 100 router. The router is not showing as broadcasting but the green light it on.
  • Linksys Master
  • 6,487 Answers
If the router is not broadcasting teh best way to fix this problem is to reset the router by pressing the reset button of the router for 15 seconds then afetr that run again the setup cd of the router or manually reconfigure it back....
Posted on Nov 30, 2008
Cannot find wirelss router on aspire 5741
First try the easy stuff. Press Fn+F3 keys and ensure that WiFi is enabled. If that is OK, then a question. Are there any other wireless devices currently hooked to the router? The router has what is called an SSID that is broadcast so WiFi devices can sense the network. Once the device sees the SSID, then you can select that network and connect (providing that you have all the security passwords). If the SSID of the router is not being broadcast (that IS an option), then your device will not see it and you must manually input the SSID name in order to link to the network. This is used by some as an extra layer of security, especially in highly populous areas.
Jan 08, 2012 | Computers & Internet
I bought a Belkin wirelss router for m panigital novel. It conecedtomy PC whiich has a modem. It states the connection is excellent but disconnecs within miutes. in e-mail mode where do I ind the the...
If you're talking about disconnects between the modem and your PC, check to see if your network cable is hooked in properly and make sure it's not showing signs of damage. If you're surfing wireless, try changing the wireless channel (frequency) your modem broadcasts on.
For problems with the modem losing its internet connection, try checking the cabling between the router and the telephone socket or coax socket, or make sure to contact your ISP and ask them to test your line.
Mar 05, 2011 | Computers & Internet
My router will randomly stop broadcasting its signal and shows a green light that it is connected to internet but still wont broadcast i have to unplug it for about fifteen secounds for it to start...
You will need to update the Firmware in your computer to do that here is a direct link to show you how step by step Good Luck.
http://en-us-support.belkin.com/app/answers/detail/a_id/497/related/1/session/L2F2LzEvdGltZS8xMjk0OTI5NDU5L3NpZC8yUlBkZlpqaw%3D%3D Copy and paste into address bar.
Jan 13, 2011 | Belkin Basic Wireless Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
My son keeps getting an error 5200 on his ds when trying to hook up to wifi
Hello :
1:Try adjusting the "Channel" your wireless router broadcasts on. I highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
2:Check your router's broadcast settings to find out if it is set to "G", "B", or "Mixed." Mixed typically works best, but try all three to see if it improves the network connection to the Wii console.
3:Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off. Wireless keyboards and mice may also cause interference.
good luck .
rate please !
Mar 20, 2010 | Nintendo DS Lite Console
How do I hook up a G wireless router to my h/p computer
The usual setup is to connect your internet cable or dsl model to the WAN port on your wireless router. any devices that were formerly connected to your cable/dsl modem then get connected to the LAN ports on your router. You will need to connect to the wireless router via etehrnet cable the first time in order to setup your wireless connection, it's usually a simple setup following the prompts.
Sep 29, 2009 | Belkin (F5D8231-4) Wireless Router...
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
I'm trying to hook up the WRT54G wireless router to my laptop and it doesn't work! Help!
If you go into the setting on your router you need to enable wireless broadcast as it sounds like its not broadcasting.
Is the wireless adapter enabled in network connections? Newer laptops with built in adapters have a button abve keyboard to switch it on and off.
What is the model number of your laptop?
Dec 27, 2007 | EliteGroup ECS A535 Notebook
Router to use as relay.
Linksys WRT54GL with DD-WRT firmware. Now, DD-WRT will void the warranty, but it has been incredible for my uses when configuring WDS. A the WRT54GS has also been said to be an excellent router, but I cannot say.
Dec 22, 2007 | D-Link AirPlus DI-524 Wireless Router
Linksys RangePlus WRT100 Wireless Router Logo
98 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
