Question about Dynex 30-Pin Dock Adapter for Apple iPod shuffle
What does the little electrical bolt symbol mean?
I have an iPod Shuffle, and I have plugged it into a Dynex adaptor.  I recently bought a Logitech Pure-Fi Anywhere-2, and planned to use the set up for about 7 hours of music at a party.
My iPod Shuffle stops episodically, until I turn it off, wait a bit, & start again--- obviously not good for a party.  My question relates to wondering if I have been using more power than I need to.  I had thought the iPod Shuffle would automatically recharge, as I have the speaker system plugged in (rather than running on batteries).
I have switche on the speaker symbol (green) on the Dynex, but should I be playing the music with the symbol switched to the electrical bolt symbol (red), and is that even possible?
Is there something else that would help?
  • ellend99 Dec 27, 2008
    I listened to my shuffle for 5 hours after charging on the dock using the dynex adaptor. now it has stopped. what is the lightening bolt? no one answered this question, but instead gave other information????
This is obviously a power or connectivity issue, check that the device ( your ipod ) is correctly seated into the logitech speaker system, and check the power cables are connected according to the manual which came with the logitech speaker system.
question u may ask yourself? - does the ipod work as it should on its own? (without non-apple devices/components attached to it) - if it doesnt - take to an apple store or call or seek apple support.
it sounds like your ipod is low on power from source.
i hope this directs you in the right direction, party on!
Posted on Dec 01, 2008
Wen i connect my i pod to computer it does not connect
Check to see whether your iPod shuffle is the original stick version or the newer version, which plugs into the iPod dock connector.
Turn your PC on.
The PC needs to be on to transfer music and charge the iPod shuffle.
Place the iPod shuffle in the iPod dock connector if you have the newer version.
If you're using the original version, then plug it directly into a high-power USB port on your PC.
Check the monitor to ensure iTunes has loaded.
This means a connection was established.
hope this helps
Oct 11, 2012 | Apple iPod shuffle MP3 Player
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
I have an ipod shuffle which doesn't fit the sing sing panda my son has bought. will the nano 8gb fit in the dock and charge. thanl you susan
if its a new one with smaller ipod plug you can buy an adaptor which will fit into the ipod and has the old larger socket on the base which plugs into the panda
Dec 26, 2010 | Audio Players & Recorders
Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod . It keeps shutting off after a few minutes. It's plugged into a wall outlet.
Many have reported the same issue, reset the pure-fi with the reset switch (on bottom) while it is turned on, then put your iphone/ipod at 75+ % of volume before/while playing.
Feb 21, 2009 | Logitech Pure-Fi Anywhere Portable...
Settings/content pane in itunes for adding songs does not show up
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod shuffle. Try
these steps one at a time until the problem is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
â Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
again.
â Retry with a different USB port if you cannot see iPod shuffle in iTunes.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod shuffle. See “Updating and Restoring iPod shuffle Software” on
page 26.
Jul 16, 2008 | Apple iPod shuffle Second Gen. Silver (1...
My iPod shuffle will not charge
If iPod shuffle won’t turn on or respond
â If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
â Turn iPod shuffle off, wait five seconds, and then turn it on again.
â You may need to restore iPod shuffle software. See “Updating and Restoring
iPod shuffle Software” on page 26.
Jun 25, 2008 | Apple iPod shuffle MP3 Player
Ipod shuffle (2nd generation)
alright, when you plug your ipod in you will see on the bottom right of your screen (the task bar) that there is a wierd looking symbol right click it and click safley remove. if you dont see this symbol symply click start or look on your desktop for the "my computer" button open it and it should show your ne of your drives saying ipod something right click it and click safley remove
Jan 30, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod problem - playing songs in order
sounds like you need a new hard drive, which has a little read-write disk in it that is getting finicky... just to get more use out of it lay it on side or other positions and hear if works ok...if so its diffently Hard drive. you know the sandisks are 2 gigs no moving parts why doesnt somebody put 20 together making 40 gigs and replace the failing Ipods!!??? just pure electronics and no moving parts and much smaller...not like a hard drive. I thought of this over 30 years ago looking at the first plug in video game.
Aug 31, 2007 | Apple iPod shuffle MP3 Player
Power problem
probably "+" you need to check the polarity of the speakers, there should be something like this near where you plug in the power adapter: http://www.accesscomms.com.au/images/reference/powerplug-positive.jpg the above symbol would mean "+".
Feb 01, 2007 | Logitech R-20 Computer Speakers
Dynex 30-Pin Dock Adapter for Apple iPod shuffle Logo
404 people viewed this question
Top Dynex Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
