Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
"weak signal" on my RCA scenium
Hey, I gotta RCA Scenium HDTV big screen and about 5 months ago i unplugged it to move it to another room and then i tried to use it and everything was saying weak signal and it was a black screen. But all the menu options work, but cable, or any rca input would not show a picture and the sound would come for 2 seconds then go then repeat. Some guy told me to unplug it for 10 mins and try it again, sure enough it worked. So couple days ago i had to unplug it again and now when i try to use it to watch my dvd or anything, its saying weak signal again. Whats weird is, my XBOX 360 is still working fine, maybe cause its HD ???? PLEASE HELP- I cant find any help and i need my Tv back. Thanks
  • 1 more comment
  • gdent Dec 02, 2008
    help! trying to hook up my cable to tv. plugged it into ant a port, nothing, ant b, nothing. tried doing a channel search and it says no channels found. it shows "weak signal" on the main screen. on main screen, it shows channel 0, how do i manually change the channel on the main screen? i know it should be on channel 4 for my cable to work? help!
  • patricia_rob Dec 22, 2008
    My RCA Scenium DLP HDTV shows that I have an unusable signal but when I check all of the connections everything is fine (the signal strength on the menu says it is fine) when I put it on a DVD or Cable input it will play about 2 seconds of sound (no pic) and then go silent with a black screen.
  • girlygirl143 May 12, 2009
    I have a HDTV and for a while my cable was working perfectly fine then all of a sudden the cable just went out and it says Unusable Signal, it has NO sound or anything.. I put it on Disney and its all static but that is it.. Please help me
Hi, I got the same problem and unplugging fixed it but I just want to add that only my 4 REGULAR Video inputs (Vid1 to Vid3 + Front) are affected. The Component input, using 3 cables for Video input is not affected by this problem. Stephane
Posted on Oct 08, 2012
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Posted on Apr 12, 2007
  • Gilles Brassard Apr 13, 2007
    Hey Me again,
    Just to tell you that yesterday I have decided to unplug my TV once again from the wall. Left as is for 24 hrs. I just pluged it in and my TV started working again. Don't know why this time it work but hey! It did. So try it out. Hope all works out for you to.
    Gilles
No picture/sound
YOU HAVE AN INTERNAL TUNER FAILURE IT NEEDS TO BE REPLACED
CONTACT RCA FOR REPLACEMENT PARTS OR INFORMATION
here are some contact information for rca
http://www.rca.com/content/viewdetail/1,2811,EI45168,00.html
Questions about operating or setting up your
HDTV: Call us toll free at 1-866-SCENIUM
(1-866-723-6486), or send us an email.
Quality comments? Call us toll free at
1-866-SCENIUM.
Jan 06, 2008 | Televison & Video
M61WH185 rca scenium front panel flashes 5 times and no picture
this is the tv's way of saying that my lamp is getting weak or is about to go.
Sep 06, 2010 | RCA Scenium M61WH185 61" HDTV
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
RCA Scenium
What does the picture look like when it is on?
Dec 03, 2008 | RCA Scenium D40W20 40" Rear Projection...
Our RCA Scenium HDTV has had white lines outlining the scenes
You may have a failig tuner, can you get me a pic of the screen? Does it have a analog tuner or digital or both? If its an analog tuner I wouldnt worry about because after february of next year all over air signals will be digital.
Dec 02, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium HD52W140
I cannot think of anything easy that would cause the symtoms you are describing. Your power supply is working and the deflection bd is good because you have HV. The problem is signal related and all of this circuitry is on the SSB or small signal bd. The difficult thing is when replacing this bd. you must have RCA's chipper check to download all of the ssb eeprom settings so they can be uploaded to the new ssb. I'm affraid you will need a qualifier RCA service tech for this problem.
Feb 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Poor screen resolution and unable to get channel guide.
The channel guide is a service just like closed caption. Rumer has it that it's not going to be around for much longer. The only fix is to unplug set ..wait awhile till memory loss occurs...plug back up and do a setup. Nothing in the TV will cause partial guide. Weak signal could and cause fuzzy picture too. Complain to cable company. But brightness problem is something else.
Dec 27, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
886 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
